A. Comments on
final hp heater by kerns method.xlsx calculations.
A1. Parameter table: Condensate enthalpy=925 kJ/kg, pressure same as of steam. Cooling water temp out = 200 oC, operating pressure does not affect heat transfer. See posts of 13 Oct by kkala.
Nevertheless above issues have been corrected in "My Heat Exchanger" sheet. Just make a heat balance (see excbal.xls of 13 Oct) to check / revise data, so that heat given by steam = heat taken by water (not 3326 kW versus 3495 kW, difference not being a matter of heat losses). If others have given the data, ask for clarifications.
A2. "My heater exchanger" sheet : Steam of 359 oC is first desuperheated (giving 355 kJ/kg), then condensed (giving 2230 kJ/kg). For shell side whole heat transfer, you can assume condensation temperature (216 oC) and heat transfer coefficient (U) of condensing steam. Superheated steam has lower U and higher temperature, more or less offsetting each other. This concept has been applied, may be known to others, is most probably reported in Mc Adam's "Heat transmission" (McGraw-Hill, 1954). Accordingly LMTD = [(216-175)-(216-200)]/ln(41/16) oC = 26.6 oC (instead of 87.1 oC taken). Only if steam were not condensing (no phase change) could LMTD have been 87.1 oC. And "
Shell side mean temperature is close to that of saturated steam (216 oC), if it has some importance".Separating the exchanger into two parts, one to desuperheat steam - rest to condense it, would give more precise results, especially in this case of high steam superheat. But calculation would be much more complex (how to elaborate it on a real exchanger?). Let the software do it (if this is possible) to see the difference.
Other comments on the sheet:
-Check tube side coefficient (water) of 20004 W/m2 oK, usually*~4400 W/m2 oK.
-Check shell side coefficient (steam) of 1084 W/m2 oK, usually*~9500 W/m2 oK (no air in steam). Calculation might not be necessary for condensing steam, see
http://www.cheresour...h__1#entry38266, post 19 Apr 2010.
-Consider average U for fouling, not the highest.
-In theory new trials have to be made, until assumed overall U ~ calculated overall U, or assumed area ~ calculated area.
(*) From C. R. Branan "Pocket Guide to Chemical Engineering", Gulf, 1999.
B. Please also explain reason of negative feed back on kkala's second post in 13 Oct 2011, as requested.
Edited by kkala, 15 October 2011 - 11:20 AM.
