What Is The Different Between Tempered Cooling Water And Ordinary Cool
Posted 11 October 2011 - 11:47 PM
Posted 12 October 2011 - 01:18 AM
I understand the difference between tempered cooling water and chilled water . Ordinary cool could refer from water stored in a storage tank or a pond .
Others may have different opinion.
Posted 12 October 2011 - 12:59 PM
Posted 12 October 2011 - 02:10 PM
Refer the attachment for what a tempered cooling water system is all about when used as a cooling circuit for a cooler (heat exchanger).
Posted 18 March 2013 - 03:01 AM
Tempered water is water in the temperature range from 85°F (29°C) to 110°F (43°C). This system is preferred to be used when you have a 30 Deg.C difference between summer and winter cooling water temperatures as it will reduce OPEX (Cost of pump operation+Cost of Pump Maintability). Pumping cost of this system is reduced because the pump has to develop only the pressure loss across the heat exchanger which is usually much less than the pressure difference CW supply and return headers. The disadvantage of such system is that you need a pump for each heat exchanger.
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
