I am involve in developing a conceptual design proposal for of a gas plant which would have LPG as product.
A model was developed using HYSYS as shown in the attached document. The attached document shows that propane and mixture of i-butane/n-butane from the De-propaniser and De-butaniser respectively is combined inside a splitter model to obtain pure component of propane and n-butane at a ratio of 30:70 respectively.
I need to confirm if LPG is a mixture of propane and n-butane only OR a combination of propane and (mixture of i-butane and n-butane).
If only n-butane is required in the LPG, what equipment or design principle can be used to split i-butane from the n-butane component from the De-butanizer gas stream?
I appreciate comments and reviews from you all.
Thanks for your anticipated cooperation.
