Hi all, We are operating 1300 KM long 16'' LPG pipeline system. We are having the black powder problem.
Is there any solution to minimise the formation of this black powder...?
Does the chemical cleaning help to remove this black powder..? Kindly explain about chemical cleaning of the pipeline.
Chemical Cleaning Of Lpg Pipeline
Started by R NESAMANI, Oct 18 2011 12:35 PM
Posted 18 October 2011 - 12:35 PM
Posted 19 October 2011 - 09:33 AM
Hi R NESAMANI
I am not expert in this field, however I have attached two pdf articles about black powder, that I seem useful to your concern.
The one is a well documented case about this problem, the other one is for brand promotion equipment.
Fausto.
Fausto.
Posted 20 October 2011 - 11:49 PM
Thank you
Posted 21 October 2011 - 04:08 AM
Good and useful stuff, Fausto, to educate those (like me) not having known about "black powder" in pipelines. It seems that chemical cleaning (in the sense that a chemical reacts with FeS) is not feasible, sorts of removal applied in practice are described in the pdf articles.
Chemical Engineering ResourcesStarted by Guest_Pilesar_* , Yesterday, 07:13 AM |
Determining Pipeline Design PressureStarted by Guest_applepe_* , 05 Dec 2024 |
![]() ![]() Energy Saving In Pump By Reducing Pressure Drop In Downstream PipelineStarted by Guest_Srinivas Agastheeswaran_* , 19 Nov 2024 |
![]() Need Help For Utility Flow Rate Calculation For A Chemical ReactorStarted by Guest_Asisr_* , 12 Sep 2024 |
