I would like to share with you a separation system design which I found interesting. This topic has been already treated in other posts.
The case referes to a three phase separation carried out in two separators, the treated oil quantities are: 15,000 BOPD; 15,000 BWPD & 5 MMSFD.
The two separators were refurbished priot to their new use and their have weirs and demister were kept. The designer chose a submerged weir separation design . As for the vessels size, the 1st separator has a L/D=4.28 with D= 2134 mm and the 2nd separator has a L/D=2.86 with D= 2134 mm.
The water and oil level controls are shown in the attachment and the separation goes on non-stop successfully since the plant started.
I have encountered other designs, overflow weir, boot, etc., but this is the first time I have seen such a design. I have checked on the references I have and the ones I can reach and, I have found no evidece of the submerged weir design. However, a friend of mine has mentioned that Shell DEP mentions the existance of the aforementioned design but there is no an actual explanation.
It seems to me that the level controls are a bit close to each other but perhaps the designer has carried out this design on more that one occasion and they have their on methodology to carry out the calculations.
In previous posts I have found that some of the replies suggest that this is not the best design (or at least no popular).
In terms of design I would hace chosen a different one. Perhaps, some of you have encountered a similar case to the one above. I just want to have your views and comments and your experience on the case.
Cheers,
