Power Calculation In Air Compressors In Polytropic Compression
compressor
#1 amit_309
amit_309
  • Inactive Member
  • Pip
  • 6 posts
Posted 16 November 2011 - 02:02 AM
hi
I am a chemical engineering student currently working on compressors for my project. I have been struck in calculating power requirement for an air compressor performing under a polytropic process. I wonder if someone can guide me with the relevant equation or spreadsheets that can help me calculate the power, bhp per stage for the compressor. i have the following data variables
suction pressure
discharge pressure
inlet temperature
discharge temperature
dry and wet flow rate of air
humidity
efficiency
k
polytorpic coefficient
please guide me as to how should i proceed
regards
amit
  • 6,715 posts
Posted 16 November 2011 - 02:12 AM
let you consider Perry chemical handbook as a resource or use the search button on this forum to get your answer .
http://www.cheresour...dpost&pid=33635
I advise you to read text book .
Hope this helps
Edited by breizh, 17 November 2011 - 06:03 AM.
