Posted 10 December 2011 - 11:59 AM
I am working on a project where I have to heat used vegetable oil for cleaning and water separation in centrifugal separator. I use two plate heat exchangers for this task, one to recover the energy from the final stream out of the separator and one, second in the line that will heat the oil with hot water. At the end of the line I intend to place immersion heater (element) to rise the temperature up to the final preferred degree.
Can anyone here supply me with layout on such immertion heater design where I will get the most possible out from the energy I put in. All comments are welcome.
thanks
thanks
Posted 11 December 2011 - 06:06 AM
project1,
Can you prepare a sketch of your proposed scheme and post it as an attachment for better understanding of what your requirement is?
Posted 13 December 2011 - 06:01 AM
Thanks Ankur,
I have a simple sketch on scan available but I can not find any option here for attachment!! Is it not possible to post files here?
project1,
Electric Heater In Regeneration Absorption BatteryStarted by Guest_alaasleem2026_* , 01 Sep 2024 |
![]() Cross Temperature In Heater Exchanger (Lng)Started by Guest_Yogan_* , 21 Feb 2024 |
Why To Maintain The Skin Temperature At 150Degc In Fired Heater ?Started by Guest_johneyissac98_* , 12 Jan 2023 |
Fired Heater Convective ZoneStarted by Guest_k.kospit_* , 23 Feb 2022 |
Gas Electric HeaterStarted by Guest_Mohamed_Mamdouh_* , 20 Feb 2022 |
