Deaerator
Posted 23 December 2011 - 08:44 PM
thanking you in advance
Posted 23 December 2011 - 10:21 PM
Posted 24 December 2011 - 12:59 AM
Posted 24 December 2011 - 01:46 AM
There is a search feature for searching topics on the forums it. Use it and you will find a lot of information on deaerators. I am posting a link on one of the posts related to deaerators:
http://www.cheresour...__fromsearch__1
Posted 31 December 2011 - 02:16 PM
-There are two basic deaerator types
α. The tray type, as in Fig 1 of http://www.cheresour...3994-deaerator/, consisting of the surge drum and the attached deaerating tower, where stripping of O2 mainly occurs.
β. The spray type, as in Fig 2 of mentioned web reference, or http://www.stork-the...-operating.aspx, where there is no tower. Stripping of O2 occurs in the drum.
γ. In boiler process duty spec we specified spray - tray type deaerator, which seems to be close to (α), not to (β), with BFW hold up time in the surge drum about 20 min.
-Some part of the design is proprietary, e.g. Stork has patent on spray deaeration. On the other hand interest is concentrated in making the duty spec of the deaerator, not in designing it, at least here. I have heard of Romanian (old) books explaining how to design the tray tower though.
-However following links may be useful
http://www.spiraxsar...deaerators.asp , from Spirax Sarco.
http://www.cheresour...-calculations/ , from forum (vent steam)
http://www.cheresour...eam-vent-flow/ , from forum (vent steam).
http://www.altairequ...principles.pdf , packed deaerator type, etc.
-It is also noted that we specify a generous margin (3 m) between NPSHa and NPSHr of BFW pumps taking suction from deaerator in boiler duty spec. This means that that deaerator has to be adequately elevated.
Edited by kkala, 31 December 2011 - 02:41 PM.
Posted 13 February 2013 - 06:12 AM
can I operate the deareator on a gauge pressure of 1.5kg /cm2 if I maintain the water inside it at a temperature of 126 'C (saturation temperature at 2.5 kg/cm2)??
Will the BFW quality suffer???
Posted 13 February 2013 - 07:29 AM
Some links of post no 5 (by kkala) do not work now, so this part of the text is repeated below.
<http://www.spiraxsar...-deaerators.asp> from Spirax Sarco. "www.spiraxsarco.com/resources/steam-engineering-tutorials/the-boiler-house/pressurised-deaerators.asp".
<http://www.cheresour...-calculations/ >, from forum (vent steam)
<http://www.cheresour...eam-vent-flow/> , from forum (vent steam).
<http://www.altairequ...principles.pdf> , packed deaerator type, etc.
Editing note.
Links in orange can be properly accessed from following post no 6, by thorium90. Thanks thorium90 for finding these links, while I was searching for them.
Edited by kkala, 13 February 2013 - 08:06 AM.
Posted 13 February 2013 - 07:43 AM
I think you meant
http://www.cheresour...e-calculations/
http://www.cheresour...team-vent-flow/
http://www.altairequ..._principles.pdf
(Cant figure out what is the first one)
Edited by thorium90, 13 February 2013 - 07:44 AM.
Posted 13 February 2013 - 07:56 AM
my question was :
#10
Posted 13 February 2013 - 08:02 AM
Those pressures look normal to me. Its already at saturation and blowing steam at the top vent isnt it? Is there any reason why you feel the quality will suffer (as compared to) ?
#11
Posted 13 February 2013 - 10:39 AM
yeah it is at saturation temperature , but someone is telling me that gases will not strip out and when o2 levels have to be in ppb than even this much increase in pressure would lead to an increase in hydrazine consumption .
Also since a bit of steam is vented in dearation this rate would increase.
I just want to know that is low pressure deareation better that high pressure one or only the saturation temperature matters.???
#12
Posted 13 February 2013 - 10:59 PM
#13
Posted 14 February 2013 - 03:00 AM
Thanks a lot .
Do you have any pdf which I can refer to about deareators??
#14
Posted 14 February 2013 - 10:43 PM
http://www.kansascit...y-deaerator.htm
Try this company. Once upon a time they had an online sizing program.
Posted 16 February 2013 - 11:28 AM
1. Outlet water O2 concentration of 0.005 - 0.007 mg/l reported by Dr Krska (post no 12) is same as locally specified for (spray-tray) deaerators treating demineralized water at 103 oC. Not verified by measurement during boiler performance tests. Hydrazine dosing (post no 11) is expected not to be sensible to changes in O2 concentration as above. Hydrazine is added in excess, to cover its thermal decomposition and reactions beyond O2 removal. So inefficient (to some extent) deaeration may not be "caught" by hydrazine dosage.
2. Impression is that deaerator efficiency concerning O2 will not practically change by increasing operating pressure from 1.5 to 2.5 kgf/cm2 a. Once a boiler supplier proposed to increase deaerator temperature to (say) 130 oC to eliminate boiler feed water preheater (downstream BFW pumps). Deaerator performance would not be sacrificed, but we could not check that (see above). This is an uncertain indication; a general justification would be needed, considering a pressure deaerator with deaerating tower (High Level, per post no 12).
α. Equilibrium concentration (Ce) of O2 in water for a specific temperature depends on O2 partial pressure in the vapor phase (Henry's law). Vapor phase contains H2O(g), O2, etc, where O2=stripped O2. Increasing temperature to 126 oC will increase H2O(g) pressure to ~2.5 kgf/cm2 a. Absolute O2 pressure in vapor phase will not change, or it will increase quite little due to temperature increase. Thus Ce will remain as before or decrease quite a little.
β. Above concerns equilibrium concentrations. Actually water in deaerating tower contains more air in dilution than what equilibrium would dictate under operating conditions (*). This "surplus" air (and O2 content) is vigorously "shaken" out by stripping steam.
For constant stripping steam mass flow, increasing its pressure to 2.5 kgf/cm2 a decreases its volumetric flow rate by about 40%. This may or may not decrease rate of stripped O2. If it does, increasing vent rate by 40% would probably restore previous O2 removal efficiency. Specific advice from suppliers would be useful, or even from members having expertize.
γ. My impression is that deaerators of above type have great flexibility, on the other hand required vent rate is referred as % of incoming water.
Comments on this rough (incomplete) explanation are welcomed, as well as additions.
-It is noted that above results in higher design temperature and pressure to be looked into (post no 12).
(*) Betz, Handbook of Industrial Water Conditioning, Boiler Water Systems, Boiler Feedwater Deaeration (Betz, Trevose, 1976).
Edited by kkala, 16 February 2013 - 12:14 PM.
![]() High Pressure Condensate Recovery To Low Pressure DeaeratorStarted by Guest_hd_1982_* , 16 Feb 2024 |
![]() Pressurized Deaerator Tank Exhaust Vent SizingStarted by Guest_zezima_* , 01 Feb 2024 |
Deaerator Equipment In BoilersStarted by Guest_CHEMSTRONG_* , 07 Aug 2022 |
![]() Basic Principles For Designing A Vacuum Deaerator For SeawaterStarted by Guest_gohar.m_* , 19 Jul 2017 |
Deaerator Internals DesignStarted by Guest_jaivanthrao_* , 17 May 2017 |
