The relevant information from the existing exchanger datasheet are as follows:
Exchanger Type- BEU, Horizontal
Heating Surface- 26.74 m2.
Duty- 473 kW
LMTD- 32 C
Clean Transfer Rate- 763 W/m2C, Service- 436 W/m2C
Shell ID- 406 mm
Tubes- 70 U-tubes, 19mm OD (11 BWG) x 3800 mm length, tube pitch 25.4mm, square rotated.
Baffles- single segmented, 29 with center spacing of 132 mm, 19 dia.% cut
nozzles- shell inlet 101.6 mm, shell outlet 101.6 mm, tube inlet 76.2mm, tube outlet 76.2 mm. Shell side inlet at top, rear head. Tubeside inlet at top.
Shell side
60wt.% ethylene glycol, 40wt.% water (liquid)
72,000 kg/hr, max. inlet temperature 25C, 120 kPag.
Fouling Factor- 0.0004 m2C/W
Allowable pressure drop- 35 kPa
Design temp- 60C, Design Pressure- 6 barg
Tube Side
Ethylene Gas
8040 kg/hr
max inlet temperature 95C to be cooled to 43C.
Inlet pressure 11,700 kPag
Design Temp- 160C, Design Pressure- 184 barg
Based on some heat transfer analysis, my proposed modifications are:
- Increase tubepasses from 2 to 4. I expect that I will have to reduce u-tubes to 58 because of the space taken up by the pass-partition lanes.
- Replace single segmental baffles with double segmental to reduce shellside pressure drop.
- Increase baffle spacing from 132 mm to 158 mm, and %cut from 19 to 25.
- Add 2 rows of impingement rods to top of bundle to protect against erosion based on TEMA requirements.
I would appreciate any comments on the above proposal.
Has anyone done a similar project? What mechanical design considerations I should be aware of?
Edited by GS81Process, 29 December 2011 - 03:16 PM.
