As per API 520 maximum allowable over pressure is
110% set pressure for single valve
116% set pressure for multiple valves
and 121% for fire case.
but we have a relief valve which has over pressure 25%
how can justify that?
best regards
rohollah
Posted 05 January 2012 - 05:30 AM
Posted 05 January 2012 - 09:52 AM
Posted 05 January 2012 - 10:27 AM
Dear all
best regards
rohollah
Posted 05 January 2012 - 10:46 AM
Posted 07 January 2012 - 01:43 AM
Remember, there's no limit on valve overpressure. The 10%, 16% and 21% limitations apply exclusively to accumulation.
Posted 07 January 2012 - 03:18 AM
Posted 07 January 2012 - 04:28 AM
Is there any relation between accumulated pressure and life time of the vessel?
with regard to corrosion allowance is it correct to say ,accumulated pressure decreases due to corrosion?
