if you have read any of my previous threads then you may be familiar with the concept, but if not here is a small insight...
I am studying the feasibility of carbon dioxide sequestration via the precipitation of magnesium carbonate from reverse osmosis retentate.
the reaction has CO2 gas entering a vessel through the bottom of a tanks, batch reactor.
i deduced that once CO2 has dissolved into the solution forming CO2(aq) followed by carbonic acid the following equation can be deduced:
Mg2+ + CO32- <---> MgCO3 - with kf being the rate constant for the forward reaction and kr the rate constant for the reversible reaction
So for the second order reversible reaction, the following mass transfer can be obtained:
accumulation = input - output + generation - consumption
saying that Mg ions are A, CO3 ions are B and MgCO3 solid is M and concentration of each part is C:
Taking the reaction with respect to A:
VT. dCA/dt = 0 - 0 + VT.kr.CM - VT.kf.CACB
simplifies to give:
dCA/dt = kr.CM - kf.CACB
I want to solve for dt. i was thinking about changing its form as it might simplify into a form where it is not integrable
so using extent of reaction, ε we can say CA= CAO - ε, CB= CBO - ε and CM = CMO + ε which you could then substitute into the equation:
dt = dε/( kr.[CMO + ε] - kf.[(CAO - ε)(CMO + ε)])
from there though i get stuck... any ideas how to further...
since I'm claiming it is a reversible reaction (should i say that it is????), could i consider it at equilibrium meaning that the accumulation (left hand side of the mass balance equation) could be taken as 0?
any help on the matter would be very much appreciated!
many thanks!
andrew
Edited by peaston, 06 January 2012 - 12:01 PM.
