Stripper Column Design
#1 Amyyy
Amyyy
  • 3 posts
Posted 02 February 2012 - 07:28 AM
Hi
For my project, i am designing a stripper column to strip condensate from methanol and other impurities.. the only information i am given is the inlet flow rate. i am using reboiled stripper to save costs and inserting steam into reboiler from Boiler feed water at 120C .. I need to work out the amount of steam i need and number of stages for the column by drawing the VLE curve of mole fraction of vapour vs liquid .. i don't know how it done!!
#2 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 02 February 2012 - 07:51 AM
amira,
There are several methods for determining the number of theoretical Stages of a column given the VLE data, two of them are Fenske-Underwood and McCabe-Thiele.
You need to go through the distillation section of your basic engineering texts such as "Unit Operations of Chemical Engineering" by McCabe & Smith, "Mass Transfer" by Robert E. Treybal and Coulson & Richardson, Volume 2.
Some excellent web resources on the basics of distillation are available at:
http://lorien.ncl.ac...Cabe/basics.htm
http://lorien.ncl.ac...til/distil0.htm
A excel calcualtor based on the above mentioned methods is available on Cheresources at:
http://www.cheresour...ges-calculator/
Edited by ankur2061, 02 February 2012 - 07:57 AM.
#3 Amyyy
Amyyy
  • 3 posts
Posted 02 February 2012 - 08:15 AM
there is no reflux so Fenske and Mcabe can not be used
#4 Arpit_Jain
Arpit_Jain
  • 46 posts
Posted 15 February 2012 - 01:17 PM
This may help
Attached File  air stripper.pdf   248.88KB   213 downloads
