Tray Adequacy Checks For Turndown Operation
tray adequacy for turndown
#1 B-2 Spirit
B-2 Spirit
  • 46 posts
Posted 03 February 2012 - 06:27 AM
Hello all,
I am needed to perform adequacy checks for a tray distillation column. The new operation will result in lower vapor loads as the feed is heavier in nature, so I wish to check adequacy during turndown.
I have used KG tower but, it gives only one paramter that is Turndown% which is equivament to % of valves to be open during turndown mode.
Is there any other software that examines the turndown and gives result in more detalied way, such as Downcomer sealing etc...
Thansk for your help in advance....
alok
#2 aransari85
aransari85
  • 20 posts
Posted 04 February 2012 - 07:41 AM
Hi Alok,
I have seen in KG tower result details about weeping check is not in much details.
I am using sultech package for hydraulics(Internal version of sulzer).
For customer version there is sulcol package available on Sulzer site, below is the link:
http://www.sulzerche...aspx/tabid-199/
For this you have to apply for it, sulcol have more details than KG tower, it show VSF/VSFmin which should above certail value to avoid weeping at low rates..
Apart from this you can check manually also:
At low vapor rate there will be liquid passing through holes. Hole area to be selected such that vapor velocity at lower operating point will be above the weep point.
Minimum vapor velocity is given by:
uh=(K2 - 0.9(25.4-dh))/(DenV)^0.5
K2 is contant depends on depth of clear liquid on plate. Find attached graph..
which will be hw-hight of weir + how hight over wier.
how = 750 *(Lw/(denL*lw))^(2/3)
Lw-Liquid flow rate(kg/sec)
lw-wier length (m)
how- wier crest (hight above wier) mm
for even flow of liquid over plate how should be atleast 10mm
Vapor velocity through the hole should be higher than uh to avoid weeping..
I hope this will be helpful...
Abdul Rashid
#3 B-2 Spirit
B-2 Spirit
  • 46 posts
Posted 06 February 2012 - 09:00 AM
thanks bro.
have applied for sulcol but no reply, however, i will definitely chk for your manual calculations.
thanks again
#4 B-2 Spirit
B-2 Spirit
  • 46 posts
Posted 07 February 2012 - 04:45 AM
Hello Abdul,
I noticed that the formulae you gave applicable for sieve trays, I am handling moveable valves. Do we have any correlations for checking weeping in moveable valve trays.
regards,
Alok
#5 adilameen90
adilameen90
Posted 14 February 2012 - 10:22 AM
There is no weeping in the moveable valve trays.
