Odor Control From Waste Water Treatment Units
10 replies to this topic
#1 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 11 February 2012 - 11:48 AM
I am looking for some solutions for controlling the nuisance odor emanating from waste water plant units which are open to atmosphere such as "Aeration Tanks", "API Separator", "holding basins", "neutralization tank" etc.
One possibility could be to spray deodrizing chemicals on top of the tanks / pits as a mist cloud. to suppress the odor.
Could there be some other means to suppress the odor?
Are there any specialized vendors who provide know how and technology for such odor suppressing operations?
Hoping to hear from some of you regarding this matter.
#2 AZIZ_MN
AZIZ_MN
  • 64 posts
Posted 11 February 2012 - 05:38 PM
Hi Ankur sir,
very innovative idea brought by you, as you descibed that One possibility could be to spray deodrizing chemicals on top of the tanks / pits as a mist cloud. to suppress the odor.but while areator is running how long deodrize will last, instead of spraying deodrizing chemical on top of areation tank we can continueosly dose deodrizing chemical in recycle sludge(bio sludge reflux from clearifier back to areation tank) with some spefic rate then it may work, but what will be the adverse effect on biomass we have to study,(i guess deodrize is organic matter so biomass will eat it and will become healthier
:D )
pls see this link
http://Water Polluti...nology in Japan
#3 AZIZ_MN
AZIZ_MN
  • 64 posts
Posted 11 February 2012 - 05:51 PM
Hi Ankur Sir,
pls see attachment
#4 breizh
  • 6,715 posts
Posted 13 February 2012 - 12:19 AM
A few years ago , we were using Biofiltration to eliminate strong smell of Monomers from process and unloading area, Clean Tech(Aaustralia) was the contractor who set the unit for us . It was very efficient knowing that 1 ppm of such monomer was giving a terrible smell .
Edited by breizh, 13 February 2012 - 12:59 AM.
#5 jackboyz
jackboyz
Posted 16 May 2012 - 01:51 AM
Hi Ankur sir
I heard about Fuchs Oxystar Aerator. It is good waste water treatment device.
_________________
Liquid destruction
#6 Michael_K
Michael_K
  • 9 posts
Posted 22 May 2012 - 07:04 PM
Alternative solution can be hybrid-type absorption column with cellular packing.
#7 Raj Mehta
Raj Mehta
  • 150 posts
Posted 07 March 2013 - 07:16 AM
Mr. Ankur,
Can you please specify  some of the deodorizing chemicals ?
How about using Activated Carbon ? It works well as a deodorizer, apart from multiple other benefits.
Thanks.
#8 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 07 March 2013 - 08:02 AM
Raj,
This is a very old topic and was specifically targeted for odors emanating from open to atmosphere tanks encountered in a waste water treatment plant in a refinery.
The main issue in this query was how to gather the waste vapors from all the atmospheric tanks before treating them. Using activated carbon for odor treatment is not something new. It is a well established technology. However, activated carbon has its disadvantages in terms of regenerating the spent activated carbon and subsequent disposal of the finally depleted activated carbon which is an environmental issue.
Using incinerators to destroy odoriferous volatile organic compounds is considered to be a more environment friendly option since there are no disposal issues for any toxic and / or odoriferous compounds. A properly designed incinerator will allow mostly carbon dioxide and water vapor as products of combustion to be released from the incinerator vent or stack.
#9 Raj Mehta
Raj Mehta
  • 150 posts
Posted 07 March 2013 - 08:34 AM
Thanks for the explanation.
But can you mention few chemicals that are used for deodorizing purpose as you mentioned in post#1. ?
Thanks.
#10 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 07 March 2013 - 08:50 AM
Raj,
I do not know the exact chemical composition of these chemicals since these are sold only with trade names. But "Hydrogen Peroxide" is frequently used for treating odors arising out of sulfur compounds such as H2S, thiols (mercaptans). Some links are provided below:
http://www.water.sie...ERX-DS-0709.pdf
http://www.water.sie...7_solution.aspx
http://www.cescosolu...-services/odor/
http://www.h2o2.com/...ls.aspx?nsId=54
Hope this helps.
#11 Raj Mehta
Raj Mehta
  • 150 posts
Posted 07 March 2013 - 12:06 PM
Thanks a lot Mr. Ankur. I really appreciate your knowledge & the efforts you take to share it.
Take Care.
