Chemical Engineering Plant Cost Index - Cepci 2012
Posted 01 March 2012 - 12:18 PM
Could someone please help me in finding equipment cost index for 2012?
Posted 01 March 2012 - 12:57 PM
sorry i am not of much help but i am on the same boat as you right now (have a final project) and i was just wondering if you know anything on vapour pressures? i need them to design my distillation column. I made a post shortly after this one called 'vapour pressures'. sorry to do this but i am pressed for time and need help haha.
Thanks regardless and good luck with your search brother!
Alex
Posted 01 March 2012 - 12:58 PM
Posted 03 March 2012 - 01:14 AM
Thanks Alex, i will refer to the book. The vapor pressure u mentioned i think u also can refer to the C & R Chemical engineering V 6 because my groupmates was referring this book when doing the design of the distillation column. sorry to say i not really read through the calculation( including the vapour pressure part) of distillation column which my fren do, so i think i wont be able to help u.
icingrock, thanks for the link u share, but in fact i need the cost index to do the correlation/ equation calculation to do the cost estimation. anyway, thanks again ur kindness.
Posted 06 March 2012 - 08:45 PM
Posted 12 March 2012 - 05:44 AM
Alex:
You can obtain vapour pressures from Yaw's handbook from Knovel.com
Posted 14 March 2012 - 08:23 AM
#10
Posted 18 March 2012 - 11:24 PM
Alex:
They did not specify to me step by step in packed column design. sigh none of the texbook explained step by step with a sample calculation so frustrating to design packed tower.
#11
Posted 17 May 2012 - 04:22 AM
Breizh - would you happen to know the average CEPCI for 2011? Many thanks.
#12
Posted 20 May 2012 - 06:06 AM
Hope this helps
Posted 31 May 2012 - 08:49 AM
#14
Posted 31 May 2012 - 06:49 PM
Posted 03 July 2012 - 01:44 PM
You can try the IC Index. It has current and forecast values:
http://en.wikipedia....nt_cost_indexes
http://www.slideshar...struction-index
George
#16
Posted 28 March 2013 - 08:02 AM
could anybody please tell me the average CEPCI for 2012 ? thanks in advance.
#17
Posted 01 April 2013 - 03:25 AM
572.7 (preliminary)
Posted 09 April 2013 - 11:26 AM
could anyone please tell me CEPCI for 2013 ? thanks & regards.
#19
Posted 09 April 2013 - 09:10 PM
For 2013 , you will need to wait Q1 2014 to get the result !
Posted 09 April 2013 - 10:11 PM
Maybe he meant March... lol
#21
Posted 12 April 2013 - 02:17 PM
Ya ,what i need is the latest one. Thanks.
#22
Posted 12 April 2013 - 07:06 PM
post 17
Posted 13 April 2013 - 12:29 PM
Thanks ever so much...!
#24
Posted 16 April 2013 - 10:28 AM
Hey!
I'm searching for the CEPCI (for January, February oder March 2013) in the printed version of the Chemical Engineering Journal. But unfortunately I'm not able to find it.. I've read that it's at the back, but it isn't. Where should I look for it?
Thanks & regards!
@Breizh: CEPCI of 572,7 (post #17) is for which month?
Edited by strychnette, 16 April 2013 - 11:52 AM.
#25
Posted 17 April 2013 - 02:01 AM
December 2012
Chemical Engineering ResourcesStarted by Guest_Pilesar_* , 24 Apr 2025 |
Urea PlantStarted by Guest_MLGP_* , 20 Apr 2025 |
