Installing Of Control Valves In A Pipeline
Posted 05 March 2012 - 11:55 AM
please help me to tell me that why we use reducer and expander in a pipeline when we installing a control valve in that line.
i means that suppose line is of 12 inch, if we install a control valve in that line then we reduce the dia of that line upto 6 inch or 4 inch, in the upstream of the control valve and we use reducer for this purpose but in the downstream line of the control valve we use expander in that line upto 12 inch.
thanks,,,,
Posted 05 March 2012 - 08:47 PM
1. Let me answer your question by asking you three questions.
2. How did you get the pipeline size of 12"?
3. How did you get the control valve size of 6" or 4", why not use 12" control valve?
4. How did you connect the 12" pipeline to the 6" control valve?
5. If you can answer the three questions, then you should be able to figure out the answer to your question.
Edited by S.AHMAD, 05 March 2012 - 08:49 PM.
Posted 16 March 2012 - 12:24 PM
i couldnt understand your explanation, plz give ans in detail if possible.
thanks
Posted 17 March 2012 - 03:33 AM
See the attached file, you may find the answer.
Narayanan
Posted 20 March 2012 - 01:34 AM
Dmitry
Posted 28 March 2012 - 01:55 AM
Quoted for emphasis.Dear Irshad
I think what he's trying you to do is to analyze the system so that you'll know the reasons behind the sizing of pipeline and control valves.
But if you can't, let me answer it for you.
Normally, control valves are sized smaller (which are sized based on Cv, which is ultimately dictated by flow and required pressure drop) than piping (which is usually sized for pressure losses or velocity limitation).
And of course, any mismatch in piping fittings will require reducers.
To that effect, it's haphazard just to pick out a control valve off the shelf, matching it with the pipe size and expect it to work as intended. Control valve selection requires analysis (by the very least) of:
1. Flow rate required
2. Expected pressure drop
Hope this helps
Posted 28 March 2012 - 07:26 PM
2. I was hopping that you learn more by analyzing and answering the questions
![]() Breather Valves - Liquid Movement In Breathing ScenarioStarted by Guest_panoska_* , 14 Dec 2024 |
Determining Pipeline Design PressureStarted by Guest_applepe_* , 05 Dec 2024 |
Surge Analysis-Control LogicsStarted by Guest_stu_* , 30 Dec 2024 |
![]() ![]() Energy Saving In Pump By Reducing Pressure Drop In Downstream PipelineStarted by Guest_Srinivas Agastheeswaran_* , 19 Nov 2024 |
![]() Pump Dischrge Control Valve SizingStarted by Guest_Lyne_* , 04 Jun 2024 |
