I have to design acetic acid plant using MONSANTO process through carbonylation of methanol for getting my degree.will someone provide me with conversion factor,process diagram and reactor design.
thanks
Acetic Acid Plant Monsanto Process
Started by jphanda, Oct 27 2005 07:15 AM
Posted 27 October 2005 - 07:15 AM
Guest_jax_*
Posted 20 November 2005 - 02:45 PM
me tooo...any help?
lo0ol
lo0ol
Guest_R1_*
Posted 21 November 2005 - 09:10 AM
Probably best to do as much research as you can on the process in the library and net then come back with specific problems that you come across. You are more likely to get help that way.
Rees
Rees
Urea PlantStarted by Guest_MLGP_* , 20 Apr 2025 |
Going Through The Writing Process.Started by Guest_Haywardvek_* , 05 Jan 2025 |
Typical Process Of Platformate Splitter ?Started by Guest_AnbIran_* , 30 Dec 2024 |
