Posted 05 April 2012 - 04:54 AM
I tried to do this simulation setting the option "detailded heat loss" in Hysys Dynamic (Ver. 7.2) but I'm not very confident with the result. In my opinion the heat loss is very low!
My vessel is horizontal, elliptical heads, 2m diameters, 7.3m lenght, full of water, operating @ 0 barg. I need to maintain a temperature of 40°C with a minimum external temperature of -2.5°C.
Thickness of 11mm (carbon steel), no insulation and installation in pit (no wind effect). From simulation the result is 4 kW.
Any opinion about this?
Thanks a lot
Posted 06 April 2012 - 12:20 PM
Total vessel area S = 2*π*7.3+8.7 = 54.6 m2
Temperature difference Δt = 42.5 oC
Estimated heat loss Q = 4 kW = 3440 kcal/h
Corresponding U = Q/S/Δt = 1.5 kcal/m2/h/oC.
This overall heat transfer coefficient looks low, compared to e.g. 5 kcal/m2/h/oC. Look at http://www.cheresou...insulated-pipe , post No 11 and on.
Nevertheless mentioned overall heat transfer coefficients (Us) in above link are valid for a slight wind, and wind velocity has a strong influence on U.
Let us try to check U under natural convection (wind velocity=0).
G. G. Brown, "Unit Operations", Wiley 1950, Chapter 29, Natural Convection, quotes following heat transfer coefficient (Btu/ft2/h/oF) for vertical plates over 3 ft high: h=0.3 (Δt)0.25, Δt = temperature difference between air and plate surface (oF).
Assuming this formula applicable (better proposal welcomed), h=0.3*76.5^0.25 = 0.89 Btu/ft2/h/oF = 4.3 kcal/m2/h/oC. This has supposed no heat transfer resistance in water or metal side, actually Δt is lower and h smaller, but resistance in air side must be controlling and overall U cannot be much smaller than 4.3 kcal/m2/h/oC. It could not reach 1.5 kcal/m2/h/oC.
I imagine that pit configuration is not considered in Hysys, the vessel is assumed in ambient air of -2.5 oC around it (with no wind).
Conclusion: According to the above, heat loss of 4 kW (through Hysys Dynamic) is judged underestimated.
Edited by kkala, 06 April 2012 - 12:39 PM.
Posted 10 April 2012 - 02:38 AM
However I also found some sources where the Overall Heat transfer Coefficient in still air is given at 0.2 Btu/hr ft2 °C that is about 4.1 kJ/m2h°C.
Posted 10 April 2012 - 03:18 AM
Have a look at this PDF attached and let me know if this can help you.
Shivshankar
Posted 10 April 2012 - 03:41 AM
Posted 10 April 2012 - 04:30 AM
@Shivshankar: the theory is critical to the engineering calculation, but in this case the result is strongly influenced by the right choice of the proper coefficients. Moreover my idea was to have a rough estimation of the right value without spending a lot of time in detailed calculation.
Edited by Stefano, 10 April 2012 - 04:32 AM.
Posted 10 April 2012 - 05:52 AM
Can you put your worked calculations here so that members will have more idea about your work.
Shivshankar
Posted 10 April 2012 - 06:17 AM
Hysys gives 1.65 kcal/m2/h/oC, "other source" 1.0 kcal/m2/h/oC (0.2 Btu/ft2/h/oF). This fair agreement is an indication of correct result, if the "other source" is reliable, minimizing possibility of error in treating / inserting data into Hysys.
Sources from the posts give higher overall heat transfer coefficients. I think that "natural convenction", even in a pit, is rather theoretical. Once I was measuring surface temperatures of a rotary drier (~60 oC) in a closed building (fertilizers), yet I felt several air currents from distant slops or openings. So it is not bad to be reasonably in the conservative side.
Comments / data from others would be welcomed.
Edited by kkala, 10 April 2012 - 06:18 AM.
Posted 10 April 2012 - 08:37 AM
Now, just for feed the discussion, I found in my "Mechanical Engineering Manual" (Ed. Hoepli 2002) a formula valid for horizontal cilindrical surfaces in natural convective contact with air
Constraint: (Gr*Pr)<10^9
h=1.32*(dT/D)^0.25
dT=42.5 K
D=2 m
h=2.83 W/m2°C
Assuming the other terms of equation negligible I can suppose U equal to h (1/U=1/h1+dx/K+1/h2)
So Heat Loss H=2.83*46*42.5=5530 W=5.53kW
#10
Posted 10 April 2012 - 04:21 PM
2. What is conservative in this case? Higher heat loss is understood to be so.
3. Referring to post No 6, chart indicates U a bit higher than 12 kcal / m2/h/oC (at conditions) for stil air. It concerns tanks with two flat ends, since their surface area is πD2/2. It is conservative. Chart by Armstrong, http://www.armstrong...s/pdf/AH630.pdf '> http://www.armstrong...s/pdf/AH630.pdf , indicates heat losses corresponding to U ~ 8.3 kcal/m2/h/oC under same conditions.
4. 2008.pdf attached to post No 4 indicates 4.3 kcal/m2/h/oC (6.20, natural convection?), based on the lowest value of given range 5-30 W/m2/oK.
Edited by kkala, 10 April 2012 - 04:23 PM.
#11
Posted 11 April 2012 - 05:28 AM
Batch Adsorption: H/d Ratio For Vessel SizingStarted by Guest_Victor_process_Engineer_* , 28 Feb 2025 |
