I am working to calculate the thickness of insulation for process pipes carrying super heated as well as staturated steam I have forlmulia to calculate it but I want to know basic refrence for this topis any one have good book or literature please share me .
thanks in advance
i am new at this site and do not know well how i will get this refrnece so if any one have then plz inform my email id is matifch41@yahoo.com
Insulation Thickness Calcualtion
Started by atifprocessengineer, Apr 09 2012 06:42 AM
7 replies to this topic
Posted 09 April 2012 - 06:42 AM
Posted 09 April 2012 - 07:09 AM
Let you try this resource .
Hope this helps
Hope this helps
Posted 09 April 2012 - 11:29 PM
Atif,
Download the insulation and pipe heat loss calculation software from the North American Insulation Manufacturer's Association (NAIMA) website at the following link:
http://www.pipeinsulation.org/
The program is one of the best there is for heat loss and insulation thickness calculations from piping.
Posted 10 April 2012 - 12:07 AM
thanks Ankur
Posted 05 May 2012 - 04:11 AM
Dear All
i need to calculate insulation for a propylene spherical tank in -46c .
do you have any idea about insulation material or insulation calculation for this???
thanks
thanks
Posted 24 May 2012 - 09:41 PM
Hello guys,
I am pretty much in the same situation as Atif but now it seems that the solutions given by breizh is good enough (haven't tried the software as per ankur's link but I believe it will be too).
Anyway, just wanna share the approach that I did and the problem that I faced (i.e. availability of convection heat transfer coefficient for water/steam at different temperatures) and hope to get feedback from you guys on what I did wrong and how different it is from breizh's spreadsheet.
Heat Loss from Steam Pipe.pdf 519.07KB
318 downloads
breizh, I presume I can also determine the insulation thickness by specifying T2 using the Goal Seek in Excel?
Cheers!
Cheers!
Posted 06 June 2012 - 06:40 AM
Hello to all
I am trying to locate a calculator for insulation thickness required to maintain a minimum temperature withing a vertical cylindrical tank with roof - can anyone point me in the right direction?
John Lyndon-Taylor
John Lyndon-Taylor
Posted 06 June 2012 - 12:56 PM
JLT,
The same methodology applies to vertical cyclindrical tanks as to pipes. You may refer the following to help you:
http://igs.nigc.ir/igs/BP/rp52-1.pdf
http://www.energyman...df/P12Abhay.pdf
Ice Layer Thickness CalculationStarted by Guest_vsnlbom_* , 04 Jul 2024 |
Hot InsulationStarted by Guest_Lyne_* , 14 Apr 2024 |
How To Calculate The Thickness Of A Wall Of A Dewar?Started by Guest_Indehiscent_* , 30 Jan 2024 |
How To Determine Wall Thickness Of Reactor If Pressure Is120Kpaand DiaStarted by Guest_chemtoli_* , 04 Jun 2023 |
Hydrocarbon Thickness Measurement On ReservoirsStarted by Guest_Bartek_* , 18 May 2022 |
