I try to design a drain connection for a new 10m (D) x 10m (H) storage tank.The Tank foundation is exist and I want to provide a side drain from the Tank to avoid any foundation modification.In this regard, I have two option:
1- Providing Cone up bottom
2- Providing Cone down bottom
As tank has mixer, as per vendor recomendation for option 1 we need at least 3 m low low liquid level, the result will loosing of 30% of gross voulme, also 10% of volume need to consider for freeboard above overflow nozzle (Tank is open top).That means with this design effective volume should be around 50-55% of total gross tank vloume.
2- For option 2, we need to consider a internal piping for using syphoning effect to drain all of tank inventory to cone lowest point.As this drain line should be free drain without any pump, could you advise me how I can be sure all of tank inventory can be drain with this method? For your infrmation existing foundation height is 600 mm above ground.
Afshin
Edited by Afshin, 16 April 2012 - 09:22 AM.
