Posted 15 November 2005 - 07:32 AM
There is a table in Perry's Handbook Chemical Engineers' Handbook (table 2-109 in 1999 edition) that shows density for methanol/water mixture at 5 different temperatures (0, 10, 15, 15.56 and 20°C) and for 0, 1, 2,...,100% methanol concentrations.
When you put this data (for the temperature in your lab, e.g. 20°C) in a spreadsheet you can fit a 2nd order polynom through the datapoints. With this equation you can now find the density given a certain MeOH concentration.
Of course you can also skip the curve fitting part and read directly from the table. For example, a 40% MeOH mixture has a density of 934.5 kg/m3 at 20°C.
Since this is a student forum I think you have to find the table and the equation yourself (I am not going to do your homework).
