Hello everyone!
i would like to have your experienced comment on a problem i am going to face sooner.
In a recent project we designed heavy naptha and kerosene treatment unit for a client.
The problem revolves around the drainage system of this unit. i want to calculate the height of seal to protect the sloped line in fire case. I don't have any past experience about designing a seal of drainage system.
There are seven vessels in this treatment unit. Each vessels drain size is 2". the flowrate i assumed of draining each vessel is 56 USGPM, the main header line is of 6". The length of line to API sewer is about 17 meters.the slope i used is about 1:100.
The Vapor pressure of hydrocarbon is 1.982 psia @ 125 C and 150 bar.
i used a basic formula for height calculation
P= rho * g* H,
but i am very sure that there should be another way to calculate this seal leg height.
since i will be ask to determine this height later, for sake of time saving. i would really appreciate if some one can give me an insight / helpful comment/ experience of seal leg designing now.
regards,
Ammad khan
Hydraulic Seal Leg Height
Started by Musab Ammad, Apr 27 2012 08:49 AM
seal seal height hydraulic seal
Posted 27 April 2012 - 08:49 AM
Posted 27 April 2012 - 09:46 AM
Ammad,
Ahmad Khan,
If go through past thread, below
http://www.cheresour...eal-leg-height/
Read the graham232.pdf provided by briezh.
Hope this help you.
Shivshankar
Ahmad Khan,
Hope this help you.
Shivshankar
Posted 29 April 2012 - 11:46 PM
thanks shivshankar for your comment.
but my case is not about vacuum condensation.
it will be desired to provide a goose neck type seal, for preventing the fire in loop.
thanks i got one formula from the referenced link.
if i could have any good reference/practice about this i will be very grateful.
regards,
regards,
Hydraulic CalculationStarted by Guest_applepe_* , 06 Oct 2024 |
![]() Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Water Seal Pot Of Prv Working PrincipleStarted by Guest_panoska_* , 23 Feb 2024 |
Kettle Reboiler Designe Rules - Position Weir, Height Weir, Liquid LevStarted by Guest_Otthigh94_* , 17 Jan 2024 |
Gas Seal In Hydrogen Vent StackStarted by Guest_Afshin445_* , 27 Dec 2023 |
