EDD has two different location of water injection into crude oil which are before mixing valve and via water header above the electrod plates.
My question is,
1) what is the usual percentage of wash water (WW per total crude flow) should be supplied to this type of Desalter? is it 3 or 6%?
2) which route should I be giving more wash water? is it the one before mix valve or via top water header?
FYI, this desalter is treating heavy crude with density hovering around 0.878 kg/m3.
Edited by sp3d2, 02 May 2012 - 10:08 AM.
