Horizontal 2-Phase Flow Correlations
Started by Aylool, May 09 2012 12:55 AM
Posted 09 May 2012 - 12:55 AM
Can anyone explain the applicable flow correlations for horizontal two-phase flow?
I just need a starting point for my assignment.
Posted 09 May 2012 - 01:01 AM
Let you consider this resource :
http://www.wlv.com/p...ata/db3ch12.pdf
http://www.wlv.com/p...ata/db3ch13.pdf
Edited by breizh, 10 May 2012 - 12:14 AM.
Posted 09 May 2012 - 02:10 AM
ahaayoub,
Flow correlations for horizontal and inclined 2-phase flow are:
1. Beggs & Brill (frequently used)
2. Eaton for Holdup and Oliemans for frictional pressure loss
3. Hughmark & Dukler
4. Lockhart & Martinelli (for laminar flow only)
5. Flanigan
5. Flanigan
Posted 09 May 2012 - 05:30 AM
Ahayoob,
On & above Mr. Ankur has suggested following correlation methods used for two phase (VL) flow calculations
1. Aziz, Govier & Fogarasi,
2. Baxendell & Thomas,
3. Duns & Ros,
4. Gregory Aziz Mandhane,
5. Hagedorn & Brown
But HYSYS is useing Beggs & brill method by default. This is one of the most accurate method.
3. Duns & Ros,
5. Hagedorn & Brown
Edited by jrtailor09, 09 May 2012 - 05:30 AM.
Posted 09 May 2012 - 06:42 AM
http://www.geocities...001/biphase.htm
You may consider these resources to support your calculations.
Posted 13 May 2012 - 04:50 AM
ahaayoub,
Beggs and Brill method for horizontal flow. Hope this helps.
Find attachement.
http://www.boemre.go...s/300/300AE.pdf
http://victas.spe.or...surance2005.pdf
http://etheses.notti...andez-Perez.pdf
http://www.fekete.co...te-pressure.htm
Shisvhankar
Find attachement.
Shisvhankar
Edited by Shivshankar, 28 June 2012 - 06:44 AM.
Posted 13 May 2012 - 08:53 AM
1. A starting point could also be a Chemical Engineering reprint on the subject, such as http://www.che.com/articles/1985-1999/Vol102/chevol102_num6_162.html. I had used a previous reprint (~ 1979), titled "Chemical Engineering aspects of two phase flow", where concepts and correlations of two phase flows (horizontal and vertical) were presented.
2. A comment on post No 3: Method of Lockhart and Martinelli is not applicable to laminar flow only. We first calculate frictional ΔPs that would arise if either phase (liquid, gas) flew alone in the pipe. Depending on nature (laminar, turbulent) of each supposed single phase flow (liquid, gas), a multiplier is determined for the frictional ΔP of two phase flow. See J M Coulson - J F Richrdson "Chemical Engineering", Vol 1 (Pergamon 1977), Chapter 4 (Flow of Compressible Fluids and Two-Phase flow); also Perry, 7th edition (1997), Fluid dynamics, Multiphase flow (p. 6-26).
Edited by Art Montemayor, 13 May 2012 - 11:02 AM.
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
Smr Reformer Flue Gas FlowStarted by Guest_kaidlut_* , 14 Feb 2025 |
