I have question regarding ESD system. Some ESD valves are associated with a local reset push buttons, while others do not have that option. On what basis this segregation has been established?, thanks alot.
Nabeel
Esd Valves With And Without Local Reset Push Button
Started by nabeel, May 17 2012 08:41 AM
Posted 17 May 2012 - 08:41 AM
Posted 18 May 2012 - 05:55 AM
G'day Nabeel
A local reset push button I think is intended to force an operating person to be present and able to see the ESD valve and associated equipment and therefore to observe first hand that the area is indeed safe and in a fit state ready for the valve to be opened.
The alternative is to allow reset and opening remotely sitting in a control room and a there being a hazard still be present in the field (such as a large leak) and not realise it.
Field reset can also help the maintenance technicians working or trouble shooting the valve in the field.
Dazzler
Dazzler
Posted 18 May 2012 - 09:52 AM
Dear Dazzler,
Thank you very much for your reply. It was realy helpful.
Nabeel
Nabeel
Posted 18 May 2012 - 02:59 PM
Agreeing with Dazzler, possibilities applied for numerous ESD valves in Aspropirgos refinery can be seen at http://www.cheresour...r-fire-scenario, mainly from post No 9 on. Both possibilitues (operation for control room, or from local panel at some distance from valve) are usually applied for the same ESD valve, in addition to manual operation
Edited by kkala, 18 May 2012 - 03:11 PM.
![]() Breather Valves - Liquid Movement In Breathing ScenarioStarted by Guest_panoska_* , 14 Dec 2024 |
![]() Isolation Requirement For Bypass Valves/ Movs.Started by Guest_shantanu.ghag_* , 15 Sep 2024 |
![]() Pressure Regulators Vs Control ValvesStarted by Guest_panoska_* , 19 Jun 2024 |
![]() Valves On Low Pressure Steam ServiceStarted by Guest_Ali4269278331_* , 15 Apr 2024 |
![]() Start New Topic ButtonStarted by Guest_latexman_* , 20 Apr 2024 |
