The landing pressure and temperature are fixed while I can still play around a bit with that of the supply (as we have yet to finalize the outlet pressure and temperature of the boiler). The criteria that I use in specifying the steam pipeline are the pressure drop and heat loss.
I already arrived at an acceptable solution (it is not perfect as eventhough the selected size of pipeline will give an acceptable pressure drop, the insulation thickness is much higher than usual – 270 mm – in order to obtain the desired landing temperature. Anyhow I believe a change of insulation material with lower thermal conductivity can address this which we will do in later stage). However, the issue now is on the steam velocity which is lower than the recommended value (15 m/s vs. 30 to 50 m/s).
I believe in order to satisfy this steam velocity requirement I can:
- Vary the pipe size
While reducing the pipe size can increase the steam velocity (and improve the heat loss of which can solve the issue of thick insulation) it will also increase the pressure drop (hence not meeting the desired landing pressure). If I then increase the supply pressure to compensate for this additional pressure drop, it will reduce the steam velocity (Higher pressure = lower specific volume = lower volumetric flow rate = lower velocity). Increasing the pipe size is not an option as it will reduce the steam velocity (and higher heat loss) eventhough it will help me in term of lower pressure drop.
- Vary the supply pressure (using my initially acceptable pipe size)
If I reduce the supply pressure, the steam velocity will increase but I will not get the desired landing pressure even if the pressure drop is more or less the same. Obviously I cannot increase the pressure as it will reduce the steam velocity.
Suffice to say that I am going nowhere – just going around and around – in trying to have a solution that satisfy all 3 criteria i.e. pressure drop, heat loss and steam velocity.
Is there any other option that I can try? Or:
- Is velocity of 10-15 m/s will pose serious condensation issue? (If not, I will stick to my initial solution which meet the pressure drop and heat loss requirement)
- Will having additional steam traps solve/manage the condensation issue? (If yes, again I will stick to my initial solution)
