Mollier Chart Or Diagram For Lpg
Posted 12 June 2012 - 06:47 AM
I am studying LPG vaporizer. Can anybody help me to have mollier chart OR mollier diagram for LPG?
Thanking You.
Posted 12 June 2012 - 06:59 AM
LPG is a generic term. LPG could be pure propane, pure butane or a mixture of propane and butane in various proportions with trace olefin imurities such as propylene and butylene. You need to tell us what do you mean by LPG? Also what properties do you want to evaluate from the Mollier diagram?
Posted 12 June 2012 - 07:06 AM
The system I am studying contains the LPG mixture of Propane(60%) and Butane(40%).
I want to evaluate the difference in enthalpy(heat content) at certain pressure and temperature to calculate heat transfer efficiency.
Harshad
Posted 12 June 2012 - 07:28 AM
It probably would be very difficult, if not impossible to get a Mollier chart for an LPG mixture of 60% by weight Propane and 40% by weight butane (or is the proportion in moles). I would suggest you use a simulation software to generate enthalpy data for a given pressure and temperature. HYSYS, Aspen Plus or Pro II could be useful. If you don't have access to these, then you can use the free download student's edition of the "Prode Properties" calculator from the following link:
http://www.prode.com/en/properties.htm
Posted 25 February 2013 - 10:31 AM
Dear Sir
How can I make P-h diagram for different compositions of Propane/Butane using Aspen plus or HYSYS? You mentioned that "use a simulation software to generate enthalpy data for a given pressure and temperature". Kindly describe the procedure briefly.
Thank you.
uxahid
Posted 25 February 2013 - 11:17 AM
Perhaps this might be helpful
Posted 25 February 2013 - 03:57 PM
If you have access to HYSYS I can show you how generate PH diagram for various compositions of LPG. However it will be better to use excel to generate the plots while HYSYS gives you the data.
Posted 26 February 2013 - 02:25 AM
Thank you dear both. I found it with your kind help.
Posted 26 February 2013 - 02:27 AM
I have a different software (PRODE PROPERTIES) which can generate diagrams as PH etc. keeping in account phase equilibria,
I agree with kabtik that working with Excel (or Matlab) offers the degree of flexibility required to create a Mollier chart,
with PRODE (or HYSYS or another simulator) and Excel you can create a table of values including all the possible states (liquid, two-phase, vapor, above critical) ,
these values can be generated with a series of flash operations as
constant volume
constant enthalpy
constant entropy,
constant liquid fraction
and as result you can create a complete Mollier chart.
#10
Posted 10 May 2013 - 12:28 AM
Hi Kabtik,
I have accessed to Aspen software. Do you know how to generate PH diagram using Aspen software?
#11
Posted 10 May 2013 - 02:33 AM
in this thread thorium90 has given the instructions for HYSYS,
and PaoloPemi has given the instruction for PRODE,
a number of tables P-H , P-S , P-V , T-H , T-S , T-V , S-H , S-V etc. can be calculated at some equilibrium conditions (VL, VLL etc.) with these you can easily create diagrams in Excel or Matlab or some other software application,
if you wish to include additional lines and values (as those required by a mollier chart) then you can do that with the specific methods provided by software,
see the above posts for additional information
#12
Posted 10 May 2013 - 08:01 AM
Cheers
Edited by kabtik, 10 May 2013 - 08:07 AM.
#13
Posted 14 August 2013 - 09:33 AM
sir i want lpg thermodynamic property table in three type of ratios
1. propane +butane 60%+40%
2 propane +butane 50%+50%
3 propane+ butane 40%+60%
thankks please send me thermodynamic tables.i will be greatfull to you
my mail id is
Edited by Art Montemayor, 14 August 2013 - 03:32 PM.
#14
Posted 14 August 2013 - 03:37 PM
Mukku:
I removed the reference to your email as a favor to you. Listing your email address leaves you open to a lot of trouble from other people outside our Forums - junk mail, viruses, etc.
Also, I'm afraid you are not going to obtain the services of our members in generating specific and custom-calculated Mollier diagrams for different LPG mixtures. Our Forums are not meant to give away free engineering services. You are going to have to generated these on your own.
#15
Posted 15 August 2013 - 08:56 AM
sorry sir .but i tryied a lot for hysys but i failed . i downloaded software from the link u gave above. but i am not able to install. please tell me a link from where i can download it
thank u
![]() Doubt In The Represntation Of The Pid Controllers In P&id DiagramStarted by Guest_myself_ritesh_* , 24 Jun 2024 |
![]() Looking For Mecl (R40) Enthalpy Pressure DiagramStarted by Guest_fredlan54_* , 28 May 2024 |
![]() Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
![]() Psychrometric Chart: High Dry Bulb, Low RhStarted by Guest_elliot.433_* , 13 Jul 2023 |
Looking For Enthalpy (H) – Entropy (S) Chart For Chloromethane (MethylStarted by Guest_fredlan54_* , 18 Jul 2022 |
