Volume Booster In Control Valves
volume booster control valve
No replies to this topic
#1 karthik1488
karthik1488
  • 5 posts
Posted 18 June 2012 - 04:00 AM
It'll be really helpful if someone can clarify the below points:
a) Why do we use a volume booster ?
b.) What difference does it make between using volume boosted air for stroking the actuator and increasing the Instrument Air supply pressure or are they both the same?
c) Instrument specs of volume boosters read Input/Output pressure ratio as 1:1. What does this mean?
Thanks and Regards,
Karthik
