Requirement Of Thermal Psv In Ammonia Service
Posted 11 July 2012 - 03:18 AM
Posted 11 July 2012 - 04:20 AM
There must be a lo point drain/high point vent provided to empty out the dead portion between two isolation valves. What scenario you envisage the requirement of PSV on piping. Waiting for your comments.
Edited by Padmakar S Katre, 11 July 2012 - 04:29 AM.
Posted 11 July 2012 - 05:21 AM
As far as i know, there is no fixed value for minimum volume of trapped liquid after which it would be needed to TSV installation to protect relevant piping from overpressure due to thermal expansion.
In fact, TSV requirement is a funtion of expanded volume that, in turn, would depend on trapped volume and temperature change. Then theoretically, if piping MOE (modulus of elasticity) can afford the effects of expanded volume with an acceptable margin no need to TSV installation, otherwise it should be considered.
Fallah
Posted 11 July 2012 - 08:23 AM
Robert
Posted 11 July 2012 - 04:02 PM
A general rule (not specific for NH3) is: TRVs shall be typically installed between two valves, in case that pipe length is longer than 30 m, or liquid volume is more than 1.0 m3, http://www.cheresour...n-relief-valve - post No 23.
Nevertheless http://www.eng-tips.....cfm?qid=322203 '> http://www.eng-tips.....cfm?qid=322203 , post by BenThayer, recommends thermal expansion valve between each pair of valves on NH3 lines (more conservative). I would try to follow it, due to potential hazards of NH3 handling.
However my opinion is not based on actual experience on NH3 piping design.
Edited by kkala, 11 July 2012 - 04:18 PM.
Posted 11 July 2012 - 10:21 PM
Edited by Faisal Ghafoor, 11 July 2012 - 10:30 PM.
Posted 12 July 2012 - 01:29 AM
Posted 12 July 2012 - 02:02 AM
Attachment by breizh is more complete, as well as more conservative.
Edited by kkala, 12 July 2012 - 02:15 AM.
Posted 12 July 2012 - 05:08 AM
- Thanks all. Every thing is very useful in defining criteria in our plant.
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
![]() Ammonia Synthesis Loop SimulationStarted by Guest_Said Salim_* , 05 Apr 2017 |
![]() Ammonia Gas With WaterStarted by Guest_James Clerk Maxwell_* , 09 Sep 2024 |
![]() Isolation Requirement For Bypass Valves/ Movs.Started by Guest_shantanu.ghag_* , 15 Sep 2024 |
