I had a discussion with a colleague on reading the pump head value from the attached pump curve.
Assume the throughput capacity from the pump is 1,250 gpm. From the curve, the corresponding Total Discharge Head is 164 ft.
My partner said since the TDH axis doesn't start from zero,it starts from 40 ft. Therefore, the corresponding head at 1,250 gpm should be 164 - 40 = 124 ft. My suggestion was that the value should be taken directly.
I would like to know what is the best way to read this TDH on this curve when its axis doesn't start from zero.
Your comment is highly appreciated.
Edited by asade abiodun, 13 July 2012 - 03:59 AM.
