Bulk Modulus Of Elasticity Of Lng?
#1 Windswept
Windswept
  • 3 posts
Posted 24 July 2012 - 03:48 AM
I am new to this forum, can anyone point me in the right direction......?
I am trying to calculate the pressure surge of a fast closing valve to identify the pipe period in order to reduce the water hammer effect by increasing the flow stoppage rate. To do this I am using the Joukowski formula...... I have all the details I need but it has proven difficult to obtain the Bulk Modulus of elasticity of Liquid Natural Gas, LNG.
Does anyone know or know where I can find the Bulk modulus of elasticity of LNG?
Many Thanks
  • 6,715 posts
Posted 24 July 2012 - 06:18 AM
http://www.cheresour...-of-elasticity/
Consider this resource
#3 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 24 July 2012 - 06:38 AM
Windswept,
Refer the attachment for "Liquid Bulk Modulus" as a function of density and the liquid temperature.
#4 Windswept
Windswept
  • 3 posts
Posted 24 July 2012 - 09:44 AM
Breizh,
Thank you for your reply, the thread was interesting although for LPG and not LNG.
Anuk,
The graph was a good indicator to quantify and value I finally managed to find,
This is what I found for interest or future reference: Bulk modulus of LNG 0.848 GPA @ -160 ºC
Many thanks
Windswept
#5 PaoloPemi
PaoloPemi
  • 550 posts
Posted 25 July 2012 - 01:09 AM
(isothermal) bulk modulus is the inverse of isothermal compressibility,
if you know (or can characterize) the composition any software capable to calculate isothermal compressibility can give accurate results, differently a generic value is the last resource.
Some software for fluid flow analysys requires only one value for bulk modulus not a table, for these cases I prefer to calculate several values of isothermal compressibility with Prode Properties then I select an average value (in the expected range of pressures and temperatures)
