Respected Forum Members, Good Day.
I am requesting for guidance and consultancy to setup a plant for converting SN65 & SN70 Paraffinic LOBS (lube oil base stock) into (W.M.O)White mineral oils and TOBS (transformer oil base stock) and drilling oils.
I am aware that Hydro treating is the present day process equipment to get the job done, but it a very expensive piece of equipment the investment runs into millions of dollars.
I am looking for alternate process which is inexpensive and could be deployed at a lower production rate.
Required feed input 2 to 3 cubic meter per hour / 2000 to 3000 liter per hour.
It could be batch type or continuous process, batch type process is preferred as the initial investment cost will be lower.
In my humble observation there are many medium and small companies in India and China doing the same business, but I am not aware of the process.
So I am posting my request at this wonderful forum. Please guide me.
Thanks & Best regards
Fuad Salahuddin.
White Mineral Oil & Transformer Oil Base Stock
Started by Fuad, Aug 13 2012 04:36 AM
white mineral oil tobs tranformer oil base stock white oils de-waxing aromatics removal. drilling oil
No replies to this topic
Posted 13 August 2012 - 04:36 AM
![]() Acid Base ExtractionsStarted by Guest_paradoxlost_* , 07 Jul 2024 |
Aspen Edr Error Data BaseStarted by Guest_adrich91_* , 31 Jan 2024 |
Multiple Base Methods For Stream In Aspen PlusStarted by Guest_Icehot1_* , 12 Feb 2021 |
![]() Crude Selection For Lube Base Oil ProductionStarted by Guest_Muhammad farhan_* , 20 Sep 2019 |
![]() Lpg Stock Calculation For BulletsStarted by Guest_Mugesh_* , 22 Jun 2018 |
