Currently I am calculating the heat performance of the plate fin heat exchanger PFHE. It has wavy fin on the air side and offset fin on the internal coolant flow. I am not sure which equation to use for factor for wavy fins as there is no exact literature based on it. However, I found the closest colburn and fanning factor based on the geometry is by Junqi Dong in “Heat transfer and pressure drop correlations for the wavy fin and flat tube heat exchangers”
And for offset fin, I am using colburn and fanning factor based on their geometry provided by Manglik and Bergles in “heat transfer and pressure drop correlations for the rectangular offset-strip fin compact heat exchanger”.
Is anyone able to confirm it or with better solutions?
thanks
Plate Fin Exchangers Problem
Started by Ing, Aug 21 2012 02:17 AM
No replies to this topic
Posted 21 August 2012 - 02:17 AM
![]() Material Balance ProblemStarted by Guest_vinnay1999_* , 18 Oct 2024 |
Plate Fin Heat ExchangerStarted by Guest_panoska_* , 16 Jul 2024 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
Problem With Writing Offshore Plant Design BasisStarted by Guest_Doneisbetterthenperfect_* , 01 Dec 2023 |
Problem With Writing Offshore Plant Design PfdStarted by Guest_Doneisbetterthenperfect_* , 06 Dec 2023 |
