Multiple Effect (3) Evaporator Steam Consumption Calculation
#1 vijji
vijji
  • 26 posts
Posted 22 August 2012 - 08:52 AM
Hi friends,
I would like to calculate the multilple 3 effect evaporator steam consumption.
Feed = 3000 Kg/hr, feed temperature = 30 DegC, Intial TDS = 5%, Final TDS = 30%, available steam pressure for TVR = 6.5 Kg/Cm2, Initial total COD = 70000 ppm, what will be final distillate TDS and COD?
  • 6,715 posts
Posted 22 August 2012 - 09:47 AM
Several options to support your query:
Hope this helps
#3 breizh
  • 6,715 posts
Posted 01 September 2012 - 12:53 AM
More resource.
#4 vijji
vijji
  • 26 posts
Posted 01 September 2012 - 11:41 AM
Thanking you very much..it is more precise and more informative...
#5 cntvukovar
cntvukovar
  • 3 posts
Posted 11 February 2013 - 02:28 PM
Dear
i need help in calculation of capacity
in att i have put drawing of evaporator that we wish to use
target capacity is
input 10 000 kg / hr with 8 Bx
target output is 55 Bx
could we do this with 3 stage evaporator like in att document
is there any modification needed
what is capacity of vacuum pump need
thanks for help
