Hello I am a process engineer. I have little experience with expansion turbines.
Request a quote for this equipment and the supplier gave me the following answer:
"We checked the parameter of turbo expander with booster, In This parameter, the expander end has high speed and small volume flow rate, However, you end Increasing pressure low speed and large volume flow rate, it makes That Both Sides of impellers can not match, so the technical parameter needs to be confirmed by your sides. "
Actually I do not understand, can someone explain a little more about the problem posed by the supplier.
Posted 23 August 2012 - 10:14 AM
Posted 23 August 2012 - 01:18 PM
The flow rate and pressure ratio for the expander service should be near to the flow rate and pressure ratio for the compressor service for similar molecular weight gases. The expander work will be slightly greater as it will drive the compressor. Both sides of the turboexpander must be able to operate together on the same drive shaft which turns at the same speed at both ends. The thrust forces developed by the expander and compressor also must come close to balancing each other as the drive shaft is pushed back and forth between them.
Posted 26 August 2012 - 12:46 PM
It would really help if you can provide your parameters here,
High Vibration Of Turbo ExpanderStarted by Guest_Kashif Rao_* , 28 Aug 2019 |
![]() Compressor , Expander Simulation With Prode PropertiesStarted by Guest_chemdoc_* , 06 Apr 2018 |
Expander Compressor Operation For Methane ServiceStarted by Guest_CHEMSTRONG_* , 05 Mar 2018 |
Turbo Compressor, Wet Gas SimulationStarted by Guest_mrbabu_* , 15 Feb 2018 |
