Restriction Orifice Sizing
orifice iso 5167 reynolds no. orifice plate
#1 ecovarrubias
ecovarrubias
  • 9 posts
Posted 24 August 2012 - 01:54 PM
I'm sizing orifice plates for a refinery using the ISO 5167-2 standard. This stantard states that it does not cover applications with Reynolds Numbers below 5,000. I have a couple of services where the Reynolds Number. is below this value, so I cannot use the ISO standard as a reference. Should I use another standard that covers this range of Reynols No? Or should I use another type of meter such as positive displacement meter?
Thanks in advance for your reply.
#2 Steve Hall
Steve Hall
  • 167 posts
Posted 24 August 2012 - 03:00 PM
An orifice plate will not give reliable results with laminar flow. Your choice of meters is dependant on factors such as pipe size, content of the pipe, and temperature.
#3 ecovarrubias
ecovarrubias
  • 9 posts
Posted 28 August 2012 - 07:30 AM
Thanks Steve for your reply. The pipe size is 2in Sch.40 and temperature is 100 °F for both meters. The fluids are:
- Diesel Oil
Density: 50.70 lb/ft3
Viscocity: 4.48 cP
- Fuel Oil.
Density: 53.20 lb/ft3
Viscocity: 31.31 cP
What kind of meter or measurement technology would you recommend considering this is only for referential measurement.
#4 breizh
  • 6,714 posts
Posted 28 August 2012 - 08:44 AM
you may consider oval meter :
http://catalog.gpi.n...al-grade-series
#5 Steve Hall
Steve Hall
  • 167 posts
Posted 28 August 2012 - 09:31 AM
Also try this source:
http://www.omega.com...e=FPD_sel_guide
http://www.omega.com...=F03&book=Green
Edited by Steve Hall, 28 August 2012 - 09:33 AM.
