Rotary Dryer Thermal Efficiency Issue
rotary dryer diammonium phosphate
#1 gautam_n
gautam_n
  • 5 posts
Posted 04 September 2012 - 04:32 PM
If the temperature of solids and gas at inlet is higher than that of the outlet in a concurrent direct rotary dryer, will it effect thermal efficiency calculations in any way?
I have been trying to calculate the thermal efficiency for a dryer used in DAP plant, but I am ending up with answer >1 !!! Please find the spread sheet attached with the values. Kindly point out where I may have gone wrong if possible.
  • 6,715 posts
Posted 04 September 2012 - 08:38 PM
How did you take account the solid in your energy balance ?
you need to perform a heat balance taking account all components (solid , gas) . Hin =Hout !
A simple drawing should help you (us) to vizualize all the streams involved .
Hope this helps
Edited by breizh, 05 September 2012 - 06:58 PM.
#3 gautam_n
gautam_n
  • 5 posts
Posted 05 September 2012 - 02:59 AM
I am attaching a simple diagram for the dryer , with the inlet and out let conditions specified.
#4 gautam_n
gautam_n
  • 5 posts
Posted 07 September 2012 - 12:26 AM
Hope this helps
Thank you Mr.Breizh,
I have performed heat balance to get Q= 774951.6 kcal/hr , and found the heat supplied by using the formula
Qheater = (Tg1-Tga)/(Tg1-Tg2)[S(X1-X2s + SCps(Ts2-Ts1) + Q] = 2085779 kcal/hr .
Vaporization load [S(X1-X2s] for the process is around 2101090. Then Vaporization load/Heat Supplied = >1.0
Do I have to account for any losses here,even after accounting for 10% losses, the efficiency will be above 90%. Wondering whether its feasible. Kindly provide me with some explanation and point out any mistakes on my part.
#5 breizh
  • 6,715 posts
Posted 07 September 2012 - 07:10 AM
Just to clarify with you :
enthalpy balance :
in : Solid + water imbibition (liquid phase) ; hot gas for drying with its water content (gas phase)
out : Solid +water imbibition residual (liquid phase) ; hot gas with water (gas phase ) +losses if any
Note : Prepare a table Xcel for us to review your calculation with all the material involved per stream where we can see
mass in = mass out .
Hin = Hout +losses . >>>> Hout/Hin = Efficiency
Edited by breizh, 08 September 2012 - 06:07 AM.
#6 Abel1956
Abel1956
Posted 12 October 2012 - 06:15 AM
Dear Breizh,
I would like to submit a case study concerning the performances of a DAP rotary dryer. The plant have been revamped to increase its capacity, the engineering company stated that the dryer have enough capacity. Unfortunately, the dryed product is not in specification of moisture, we get more thant 2 % instead of less than 1.5%. Could you please help me to set up the method for verifying the performance of the dryer considering this new capacity.
thank you very much for your reply.
Abel
#7 breizh
  • 6,715 posts
Posted 12 October 2012 - 06:40 AM
Abel ,
You need to review the calculation note provided by the engineering company and check the discrepency with what you are observing on the field .
