I am working on a up gradation project of a Refinery. We have Several tie-in from the existing header. I just want to know that, what is the criteria of the providing Car-seal Open/Close valve. I am mainly conscerend about the Cooling water supply tie-in, HP boiler feed water (supplied to de-superheater and waster heat reboiler), LP Boiler feed water (to de-superheater), Steam High pressure and low pressure.
The valve present at tie-in point of the these services should be provided Car-seal open or not.
Thanks in advance.
Car-Seal Open/close Criteria
Started by Shah Khan, Sep 09 2012 02:06 AM
Posted 09 September 2012 - 02:06 AM
Posted 09 September 2012 - 02:24 AM
Shah Khan,
In general, if the possibility of inadvertent opening/closing of mentioned valves by operators have been a major issue they should be provided with CSO/CSC facilities.
Fallah
Fallah
Posted 17 September 2012 - 03:08 PM
Hi Shah Khan
Attached I send you some tips about Car Seal.
![]() Closed Loop Pump Suction Line Sizing CriteriaStarted by Guest_Afshin445_* , 30 Aug 2024 |
Design Pressure Criteria For Reflux DrumStarted by Guest_KartikJ@15_* , 05 Aug 2024 |
![]() Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
