I want to calculate the boil off from an LPG double wall storage tank. The condition are
Import of LPG from Jetty:
One tank at a time shall be receiving cryogenic LPG from the cryogenic ship tanker.
LPG import flow rate from Jetty: 3,000 m3/hr.
LPG composition: C3 - 40%; C4 - 60%
Operating temperature: (Estimated) - 32 deg C @ atm pressure
Pressure at Ship pump: 10 - 15 kg/cm2g (assumed)
Density of LPG: 500 – 580 kg/m3 @ 15 deg C
LPG import line size from Jetty: 20”. Import pipeline shall be above ground, insulated line and total pipe length is 3.0 km.
LPG Storage
LPG storage tank having capacity of 50,000 m3 shall be provided. Tanks shall be double containment type, atmospheric with suspended roof. A steel-in-steel design is envisaged. The outer tank dimensions are 57 m diameter and 25 m height. There will be vacuum with perlite insulation in the annulus. The tanks are to be provide with boil off recovery system with compressor and condenser.And the insulation thickness is 1,000 mm . The inner tank dimensions are 55m dia and 24 m height.
Awating your valuable suggestions.
Thank you all.
g.raviteja
