Pulsation Dampener Requirement
pulsation dampener
#1 mamiri
mamiri
Posted 19 September 2012 - 10:10 AM
I am looking to see if anybody knows when to select a pulsation dampener for a pulsating pump. Is one always recommended to be used or if there exists a rule of design?
Appreciate your comments!
Posted 19 September 2012 - 12:22 PM
Mamiri:
From my experience in being involved in various projects using reciprocating pumps and requiring pulsation dampeners, I can tell you that the requirement depends on:
  • The pump and its characteristics (capacity, rpm, pressure differential, etc.);
  • The fluid pumped;
  • The pumping system, its layout, and piping arrangement.
Therefore, pulsation dampeners are not always required; however, it is considered smart to install them. When the pumping system is a critical one – such as a methanol down hole injection system pumping methanol in one stage from atmospheric pressure to 8,000 psig a detailed pulsation analysis is a smart procedure to employ before committing to the finalized pumping system design and purchase.
There are no “rules” of design that I know of that would substitute intelligent, sound engineering decisions in this application. The purchase and installation of a ¼ hp intermittent chemical injection pump doesn’t – in my opinion – merit a need for a pulsation study.
