Fired Heater
Guest_wanttolearnprocess_*
Posted 23 September 2012 - 08:30 AM
On what basis, I need to select balanced draft heater or forced draft heater or induced draft heater?
It will be great help, if some can throw some light on this...
Posted 23 September 2012 - 11:17 PM
Individual economic and environmental constraints should determine whether natural or forced draft furnaces will be used. In either case draught should be sufficient to supply to the burners 50% of excess air at maximum ambient temperature and 110% of design load.
Use of forced draft burners and combustion air preheat is preferred where economically justifiable.
Edited by jrtailor09, 23 September 2012 - 11:17 PM.
Posted 24 September 2012 - 06:45 AM
Thanks a lot for sharing your knowledge
I have seen crude distillation always going for balanced draft and reformers go by induced draft.
Do they have any spl. Reason for this?? Which of these type have high efficiency? in you post you have mentioned of environmental constraints, how this is going to play a role in selecting draft of a heater?
I will be great if you could elaborate on this..
Posted 24 September 2012 - 12:28 PM
1) A small heater of say 5.0 Gcal/h fired on refinery fuel gas in a refinery in the U.A.E (middle east): In this heater, it may not be justifiable to put in extra investment in the form of Air preheater, FD / ID fans, ducting, extra supporting etc. for realising fuel savings. Since local fuel gas cost is low, and the simple payback period for extra investment may come out to be say > 7 years. Hence not so profitable. It is better to specify a natural draft heater.
2) A reformer with a long convection section: A steam methane reformer has lots of heat recovery sections in the convection portion. These leads to extra resistance (in the form of draft loss) in the flue gas path. So in this case, it is apt to use an ID fan in order to push the flue gases to the disposal stack. However, in case the combustion air circuit is relatively resistance free, then air will be sucked naturally into the burners with the help of stack effect created by the tall radiant sections.
3) A large CDU heater employing recuperative flue gas cast & steam air preheaters: The flue gas circuit and air circuits are equally circuitous, (APH , STAPH, ducts, convection draft losses, air pressure drop across burners etc.). Fan on both air and flue gas circuit is necessary. More so, as the heater duty is large, reasonable air pre-heating (by recovering heat from flue gas) results in substantial savings, thereby amounting to a lower pay-back period (> 3 years) and justifying extra investment.
Hope i have helped you understand a little bit.....
Posted 24 September 2012 - 03:05 PM
Forced draft system normally includes forced draft (FD) fan and Induced draft (ID) fan. Some systems either FD fan or ID fan may be provided. If the system is installed with air preheater, normally the system will be installed with forced draft system.
The natural draft system is normally used with the furnace duty less than 4 MW.
![]() Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
Electric Heater In Regeneration Absorption BatteryStarted by Guest_alaasleem2026_* , 01 Sep 2024 |
![]() Cross Temperature In Heater Exchanger (Lng)Started by Guest_Yogan_* , 21 Feb 2024 |
Why To Maintain The Skin Temperature At 150Degc In Fired Heater ?Started by Guest_johneyissac98_* , 12 Jan 2023 |
Simulating Single Drum Supplementary Fired Hrsg In Aspen HysysStarted by Guest_andry.at_* , 25 Aug 2022 |
