Water Treatment Plant Design
9 replies to this topic
#1 Rommie
Rommie
  • 4 posts
Posted 26 September 2012 - 09:13 AM
Good day
I have been given a project to improve the waste water from our phosphoric acid plant. Currently the water is discharged onto gypsum dams and the reclaimed water reused in the process.
If it is economically sensible, the water should be pure enough to discharge back into the environment as the waste water produced is becoming too much for the gypsum dams to handle.
Current specs of the water:
pH very low, 1-2
TDS count >25000 mg/L
the dissolved solids is mainly sulphate, chloride and sodium. Fluoride, calcium, phosphate, iron and copper are also present to a lesser extent.
What I would like to know is how to find the correct combination of treatments for this water. I've read about reverse osmosis and ion exchange, I've also done some tests to see how slaked lime improves the pH and TDS count. But I have no experience in this matter, I would like for someone to give me advice please.
Am I correct in thinking I would have to neutralize the water, coagulate/flocculate the lime sludge, and then proceed with ion exchange/ reverse osmosis? Would a system like this be able to treat 2400 m3/day?
Thank you
Rommie
#2 TS1979
TS1979
  • 164 posts
Posted 26 September 2012 - 03:54 PM
I think you need to hire a water chemistry lab to find out which chemical(s) is the most efficient to get rid of the dissolved solids. Then, you probably need a clarifier and gravity filter to remove the solids. I don't think ion exchange or RO (reverse osmosis) is proper for waste water treatment.
#3 S.Chittibabu
S.Chittibabu
  • 46 posts
Posted 26 September 2012 - 10:31 PM
See that by doing lab experiment for coagulation of lime sludge, you are not increasing the TDS which other wise increase your operating cost of RO. The combination of RO followed by Demineralisation would be ideal but the end use decides the treatment scheme.
Edited by S.Chittibabu, 26 September 2012 - 10:34 PM.
#4 Rommie
Rommie
  • 4 posts
Posted 27 September 2012 - 01:44 AM
Thanks for the response!
I did a quick test in the lab. I added a 1 M solution of slaked lime to the water in a 1:1 volume ratio.
The pH increased to 5-6 and the TDS, after one hour of settling without a flocculant, decreased from 11 ppt to 1.54 ppt!
This is almost within spec for our process water regulations. For now we would be satisfied if we could just get all the wastewater to process water standard (<1420 ppm TDS and pH 6-8) it would be great if we could achieve that with just lime neutralization followed by flocculation/coagulation. Later we would consider environmental discharge, I think RO would be necessary then. It seems RO cannot handle very high TDS counts? I havent found a specific one that can handle TDS>1000 ppm.
Rommie
#5 breizh
  • 6,715 posts
Posted 27 September 2012 - 01:50 AM
Rommie ,
Talk to the floculants vendor , they should be able to perform jare tests and give you advice . Personnaly I don't think RO will do the job and the technology is expensive (correct me if I'm wrong) , most probably as stated you need to perform physical separation with floculant meaning decantation /clarification then filtration ( centrifugation or filter press ) .
Hope this helps
Edited by breizh, 27 September 2012 - 01:51 AM.
  • guestGuests
  • 0 posts
Posted 12 October 2012 - 02:42 PM
  • Agreed, reverse osmosis units would be horribly expensive to maintain in this application.
  • Most of the total dissolved solids (TDS) will be removed via pH adjustment (formation of insoluble salts, which takes the ions to a less soluble form). So, in Rommie's area, whatever the most cost effective source of basic calcium will do the trick I think.
  • Rommie will definitely need a clarifier or settling lagoon. I would have to know more about his facility before I specifically recommended a decanting process
  • CAUTION: If this is in the US, there are hard processes that one has to go through to design waste water treatment plants if they are going to discharge into a water body. Just throught I would throw that out there.
Good Luck Rommie.
#7 S.Chittibabu
S.Chittibabu
  • 46 posts
Posted 13 October 2012 - 01:26 AM
While it is economic to settle the solids and remove assludge, the local norms and disposal methods should also to be taken into account.
#8 kkala
kkala
  • Banned
  • PipPipPipPipPip
  • 1,939 posts
Posted 13 October 2012 - 03:23 AM
Wet dihydrate phosphoric acid process is undrestood (post No 1), most probably in a fertliser factory. Having worked in such a factory (~late 70s), where phosphoric acid ~30% w/w P2O5 was produced (rarely concentrated through evaporation to ~50% w/w P2O5), I think a few notes may be useful in addition to previous posts.
1. Gypsum from rotary filters normally had the look of a dry cake and was directly deposited on the ground to be transported off. Wastewaters were from filter and other washes (containing valuable P2O5) and mainly the reactor gas treatment (containing fluorides), all recycled when 30% acid was produced. In the long term it may be worthwhile investigating this possibility (of dry cake out, no gypsum settling dams), probably making operation simpler http://books.google.gr/books?id=YS0u3OpHTlwC&pg=PA452&lpg=PA452&dq=wet+phosphoric+acid+liquid+effluent+treatment&source=bl&ots=L-GcCLM8U1&sig=NGe4-mizCIWfnSIlSr-lZbnDSzk&hl=en&sa=X&ei=bAJ5UPu0JYWn4gTamYCYAQ&sqi=2&ved=0CEkQ6AEwBw#v=onepage&q=wet%20phosphoric%20acid%20liquid%20effluent%20treatment&f=false.
2. Gypsum - phosphorig acid slurries were recycled to adjacent phosphoric fertiliser Unit without separation. Produced fertilizers (mainly 16-20-0, 11-15-15) allowed for such a possibility, as well as using 30% P2O5 acid. Wastewaters from phosphoric acid process could also be recycled to that Unit. 50% P2O5 acid was produced for exports, resulting wastewater from evaporation (rich in fluorides) was sent to a global liquid effluent Unit (not aware of it, it utilized coagulants and did not apply reverse osmosis / ion exchange). Exceptional use of 50% P2O5 acid to fertilisers Unit verified that we could then consume there more wastewater per para 1.
3. It might be practical to consider above wastewater recycle limited to mentioned Units of phosphoric acid and phosphoric fertilisers; not to the whole factory, as understood from post No 4 (process water regulations). This would eliminate pH and (most probably) TDS constraints.
4. If you want to improve quality of existing phosphoric acid plant wastewater, yes, treament with lime can be a good cheap step, already discussed and realised in lab. Solubility of several Calcium salts is at http://en.wikipedia.org/wiki/Solubility_table.
Nevertheless a more radical solution could be looked into, which would also save land area.
Note: http://www.cheresour...r-flocculation, mainly post no 5, may have some usefulness too.
Edited by kkala, 13 October 2012 - 04:10 AM.
#9 sidibouziane
sidibouziane
  • 9 posts
Posted 13 October 2012 - 01:46 PM
good day.
i see most of the answers are beneficial. Mainly to one of Mr. S.Chittibabu , the end user define well which process to go with. you have the total hardness, silica, TDS... all thos can betreated either conventionally ( olicher, SAc, WAC...) chemically or using the evaporative technologies. need to know what spec you need to get to.
thanks
#10 T.S.MURALI
T.S.MURALI
  • 41 posts
Posted 16 October 2012 - 02:14 AM
Flocculation,sedimentation, clarification is possible ? Then choose this route.
TDS of the order of 25000 calls for RO.
RO-DM route decision depends on demands of Pollution control dispensation.( as cited by Mr.Chittibabu)
