I want to spray 18 m3/hr water in main pipe line having 4 kg/cm2 pressure. Water pressure is 7 kg/cm2 just at upstream of connecting with the main pipe line (means delta P is 3 kg/cm2). Water line size is 1''. Can anybody guide how many holes and of what size to be provided on 1'' pipe inside the main pipe line so that 18m3/hr flow can be established?
Posted 13 October 2012 - 11:01 PM
Posted 14 October 2012 - 12:20 AM
You may need larger main water pipe to flow water 16-18 cub. Mt/hr
Posted 14 October 2012 - 08:50 AM
The main criteria is to have line pressure drop less than 10% of the total hole area pressure drop. This will ensure sufficient atomization.
See attached article.
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
![]() Pipe Entrance And Exit LossesStarted by Guest_katmar_* , 13 Nov 2024 |
![]() Nitrogen Leak Test On PipeStarted by Guest_mesbah_* , 24 Oct 2024 |
![]() ![]() Reciprocating Pump Acceleration Head With Vertical Pipe LineStarted by Guest_Sansan_* , 18 Oct 2024 |
