Posted 22 October 2012 - 12:53 PM
Senoil:
Under normal situations, oil and gas are produced from a pressurized oil or gas reservoir. Gas that is produced together with crude oil is called “associated” gas and this gas is produced at a pressure lower than the reservoir’s because the pressure is reduced in order to separate the crude oil liquids from the associated gas. The separated produced gas has to be treated and processed in order to transport it to a marketplace for sale as natural gas. Depending on the resulting process pressure of the gas, it may have to be compressed in order to subject it to long distance pipeline transport. The compression step is done to give the gas the necessary driving force that allows it to overcome pipeline flow resistance.
Sometimes, there occurs a pure gas well where there is no crude oil liquids involved in the production. These gas wells often tend to have a relatively high reservoir pressure and consequently may not require mechanical compression for pipeline transport. However, should the well deplete its pressure or if the well pressure is not enough, then a compressor is used for transport purposes. The need for ensuring that the transported gas is free of condensable hydrocarbons as well as water moisture is also important for a pure gas well. Typical components in a gas well may be methane, ethane, propane, butane, and some pentane. The gas mixture is normally saturated with water. In order to have natural gas suitable for transport, the majority everything except the methane has to be removed prior to entering the pipeline. In order to remove these components and to transport the product methane, compression is usually required.
There are different types of compressors available for compressing natural gas. The type and driver used depend on the quantity of gas to be compressed and the differential pressure required to be added. Sometimes there is no “choice” to make in applying a compressor on a natural gas stream. The gas may not require a compression step. It all depends on the situation in the field. To continue to try to address your concerns it is far easier if you present your field scenario of gas production and your requirements for the product gas. That way we can discuss what you have to do. It is impossible to read your mind and visualize all the possible scenarios that you are contemplating on resolving with a gas compressor.
Our forums are not meant to teach chemical or process engineering. Universities do that.
