I am sizing a pc pump for water with 1000ppm oil. This pump is at the water outlet of the test separator. The flow range is 30 to 90 m3/hr.
My question is that as a pc pump is a rotary pump can I use centrifugal pump sizing calculation for the pc pump.
Can anyonekindly send a pc pump sizing calculation if available.
Look forward to your valued advice.
Thanks a ton
Progressive Cavity Pumps
Started by Prashant Process, Nov 06 2012 01:18 PM
Posted 06 November 2012 - 01:18 PM
Posted 06 November 2012 - 02:07 PM
Go to the manufacturers website. You can find some with google. Robbins is a good place to start. Since it is positive displacement, you have to vary the speed or recycle to vary capacity.
Posted 06 November 2012 - 04:00 PM
Hi Bobby,
A VSD will be used to vary speed.
I wanted to know if a valid process calculation for pc pump sizing is readily available or we can use a centrifugal pump sizing calculations instead as both are rotary pumps.
Many thanks for your response
Prashant
Prashant
Posted 06 November 2012 - 05:33 PM
Prashant,
The progressive cavity pump is positive displacment whereas a centrifugal pump is dynamic. So their characteristicts are not similar at all. You will likely find that the pc pump is much more efficient, but the manufacturer will have the information you need. And, pay attention to NPSHR for the pc pump.
![]() Centrifugal PumpsStarted by Guest_panoska_* , 01 Feb 2025 |
![]() Selection Of Type Of Pumps For "negative" Npsha And Solution TStarted by Guest_linda_pro_* , 29 May 2024 |
Vibration Of The Pump (Reciprocating Pumps / Plunger Pumps)Started by Guest_vsedhuraman_* , 06 Oct 2023 |
Variable Speed Pumps Operation.Started by Guest_panoska_* , 11 Oct 2022 |
