Hi There,
I am not sure if this has already been discussed elsewhere on this site but I couldnt find. I have a small atmospheric tank (6 m3 nominal capacity) used for storing solvent (hyrocarbon) with a flash point of 50 deg C. As per API 2000 version 1998, a flame arrester is not required if tank capacity is less than 9 m3 and has a flash point higher than 37.8 deg C. But in the newer version of API 2000 issued in 2009, tank capacity is not indicated as a criterion and flash point limit is increased to 60 deg C (meaning flame arrester is required if the flash point of stored liquid is below 60 deg C). The tank is open to atmosphere.
Any thoughts if this tank requires a flame arrester or not? As per the recommended practice/standard, it requires but is it practical to have a flame arrester on such a small tank?
Thanks,
Fz
Flame Arrester
Started by seeker_of_knowledge, Nov 07 2012 11:24 PM
Posted 07 November 2012 - 11:24 PM
Posted 08 November 2012 - 12:38 AM
Fz ,
You need to perform an Hazop around your tank . Nobody knows better than you your facility and the risks . Very little to do with the size of the equipment .
Hope this helps
Hope this helps
Posted 08 November 2012 - 04:54 AM
seeker,
i have seen flame arresters on very small tanks (0.5 m3) also. Considering that you are storing a hydrocarbon solvent with flash point of 50°C, I would recommend installation of a flame arrester on your tank. That even small volumes of flammable fluid require flame arresters is evident from the wikipedia article for flame arresters at the link below:
http://en.wikipedia..../Flame_arrester
IP15 (Area Classification Code for Installations Handling Flammable Fluids) categorically mentions that any outdooor installation storing more than 200 liters (0.2 m3) of a flammable liquid above its flash point requires a Hazardous Area Classification.
This IP 15 definition makes it clear that hazards do exist for any outdoor flammbale liquid storage volume above 0.2 m3.
Hope this helps.
Hope this helps.
Posted 08 November 2012 - 10:31 AM
Thanks Breizh and Ankur.
Fz
Fz
Posted 11 November 2012 - 05:09 PM
Although I do not have practical experience on where flame arresters are needed (not seen them installed here), please also look at following threads; indicating their disadvantages.
http://www.cheresour...lame#entry64177 '> http://www.cheresour...lame#entry64177
http://www.cheresour...flame-arrestor/ '> http://www.cheresour...flame-arrestor/ .
As noted in wikipedia, flame arrester is same thing as flame arrestor.
Burners Flame Monitoring System RequirementStarted by Guest_Movers_* , 23 Nov 2023 |
Could Flame Arresters Be Neglected?Started by Guest_Soothsayer_* , 17 Apr 2021 |
Flame TemperatureStarted by Guest_Movers_* , 11 Oct 2019 |
Flame Arrester For Hydrogen TankStarted by Guest_wojtar_* , 09 Nov 2018 |
