Simulation Of Glycol Dehydration Unit
8 replies to this topic
#1 processengbd
processengbd
  • 128 posts
Posted 08 November 2012 - 07:59 AM
SIr,
I am a process engineer. Trying to simulate TEG dehydration unit in HYSYS.
My situation is as follows
In HYSYS example file (G-2) in dehydration unit stack column has been simulated as a modified distillation column which remove water from rich Teg to make lean Teg. In the column environment they used flash separator instead of column tray. I tried this method but was unable to converge the column.
I used an absorber and a heat exchager to to simulate the unit. It converged. And showed satisfactory results.
One of the previous post in cheresources.com an engineer used refluxed absorber to simulated the stack column.
So my question is what should be the actual method. Which simulation will provide the material and energy balance of the actual real world plant.
So my simulation
Attached File  Untitled.jpg   18.44KB   75 downloads
An engineer from cheresources.com
Attached File  22-12-2009 11-36-43.png   135.26KB   103 downloads
Hysys example file
Attached File  Hysys G -2.jpg   48.17KB   89 downloads
Attached File  Hysys G -2 Column Environment.jpg   29.54KB   58 downloads
Thank you
Processengbd
Edited by processengbd, 08 November 2012 - 07:59 AM.
#2 processengbd
processengbd
  • 128 posts
Posted 10 November 2012 - 12:01 AM
Today used the HYSYS example file procedure to simulate the unit. The column converged. It showed satisfactory separation.
I took a custom column and added equipment according to example file. Then added two specification one reboiler temperature and condenser temperature.
The man reason I recon of using a flash separator in the column is that. Glycol and water has vastly different volatility simple flashing at elevated temperature would remove water from glycol. Stack column is basically used to recover some Glycol from the vapor. And stripping gas is used to get purer glycol regeneration. So in simulation we do not need to simulate stack column and stripping gas.
Thank You
Processengbd
#3 mattb
mattb
  • 9 posts
Posted 10 November 2012 - 03:07 AM
nowadays almost all simulators (Winsim, Promax, ProII, HYSYS...) allow to simulate a dehydration unit,
take care to select a proper thermodynamic model for VLE and enthalpy,
differently you may get as solution some unphysical values...
#4 Ceng
Ceng
  • 33 posts
Posted 11 November 2012 - 01:14 AM
Processengbd
TEG regenerator normally required very few theoretical stages (2 is typical), and also a very low reflux is needed.
So I guess different modeling you stated is because of what I said above. In one case the designer hasn't considered any reflux and in another case he considered the tower with 3 theoretical stages as a flash drum with reboiler and condenser.
Also note that regeneration of the glycol by atmospheric distillation at about 200 °C achieves about 1 weight % water in regenerated glycol.
To achieve less than about 1 weight % water in TEG, there are several special regeneration processes available. Examples are use of stripping gas (which has been shown in one of your examples) with or without an extra column, Cold finger , Drizo and the Read Cycle .GPSA and Kohl are general references for dehydration processes.
#5 processengbd
processengbd
  • 128 posts
Posted 11 November 2012 - 06:17 AM
Thanks everyone
Mr Mattb I used Glycol Package for my simulation. HYSYS example file uses Pengrobinson. I think Glycol package will give me best possible result.
#6 processengbd
processengbd
  • 128 posts
Posted 11 November 2012 - 06:41 AM
But I have a question in Dehydration unit simulation several component other then Glycol has been used. So for natural gas and water should I use separate property package?
#7 Ceng
Ceng
  • 33 posts
Posted 11 November 2012 - 07:00 AM
Glycol package for dehydration units with glycol will give you the best results.
But if you have other Units such as sweetening, compression, condensate stabilization etc. you should change your property package for reasonable results (for that units).
For example Amine Pkg for sweetening is suitable.
#8 momen1986
momen1986
Posted 20 November 2012 - 12:18 PM
i preparing to gas dehydration cycles and iam urgently needed hysys simulation for gas dehydration and factors affecting
#9 Ceng
Ceng
  • 33 posts
Posted 21 November 2012 - 12:13 AM
Please start a new topic and be more specific
