Hii
This is Nagarajan K
Can any one help me with what are Space heaters ?,what it relates to...?why it is used in Pumps..?...
NK.
Posted 21 November 2012 - 02:12 AM
Posted 21 November 2012 - 01:33 PM
Nagarajan,
Space heaters are not used for pumps. They are used for electric motors to prevent condensation during the times the motor is not running. They are also known as anti-condensation heaters. When applied to pumps, this means that pumps driven by electric motors and working on an intermittent basis require their electric motors to be provided with space heaters. Refer the link below for space heaters:
http://www.usmotors....ce-Heaters.aspx
Hope this helps.
Ankur
Hope this helps.
Ankur
Posted 22 November 2012 - 03:53 AM
Dear ,
Ankur
Thanks for the valuable information.
NK
Ankur
NK
![]() Centrifugal PumpsStarted by Guest_panoska_* , 01 Feb 2025 |
![]() Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
