Please, can anybody here help me with the right method to increase the temperature of a crude oil emulsion heater treater?
Emulsion Heater Treater
Started by Charlz, Nov 23 2012 03:12 PM
Posted 23 November 2012 - 03:12 PM
Posted 25 November 2012 - 05:54 AM
Can you please give more details on your query, e.g. simplified sketch of crude oil treater (indicating the heater too), content of water in crude, present operating temperature, etc? I am not expert, yet help from knowledgeable persons could be more effective with such data.
http://www.cheresour...ydratordesalter '> http://www.cheresour...ydratordesalter can be of interest. Exchangers upstream desalter are tubular (preheating train). Probably you mean something different; and temperature limits may be related to boil over.
Meanwhile, introductory material could be found by googling e.g. "breaking crude water emulsion by heating", or similar. Please confirm exclusion of "microwave" heating too.
Posted 04 December 2012 - 03:12 PM
The treater has a capacity of 40000bpd, and it is currently operating at a temperature of 64degC, which is not enough to break the crude emulsion with a water cut of 30-80%.
Posted 10 December 2012 - 02:20 PM
Unfortunately I have no experience on this treater (feed water 30-80%), having seen crude desalter only (http://www.cheresour...ing-tempriture'> http://www.cheresources.com/invision/topic/16397-de-salter-operating-tempriture), as previously said. Hopefully someone with expertise could help specifically.
Note: Fluid has probably no contact to atmosphere, which means no risk for boil over.
Posted 11 December 2012 - 08:52 PM
Chartz:
What is your problem?
Has your heater-treater previously handled the same capacity at a higher temperature?
Is your heater-treater designed to yield only a 64 oC product?
Is your heater-treater a direct, gas-fired heater? If so, can you add more firetubes?
Of the two examples I am attaching here, which type are you operating?
Horizontal Heater Treater Drawing.pdf 54.02KB
674 downloads
Vertical Heater Treater Drawing.pdf 57.14KB
757 downloads
Posted 07 January 2013 - 05:59 AM
It is a horizontal treater designed to handle the same capacity at a temperature of upto 80oC.
Electric Heater In Regeneration Absorption BatteryStarted by Guest_alaasleem2026_* , 01 Sep 2024 |
![]() Cross Temperature In Heater Exchanger (Lng)Started by Guest_Yogan_* , 21 Feb 2024 |
Why To Maintain The Skin Temperature At 150Degc In Fired Heater ?Started by Guest_johneyissac98_* , 12 Jan 2023 |
Hydrocarbon Emulsion FormationStarted by Guest_CHEMSTRONG_* , 25 Jul 2022 |
Fired Heater Convective ZoneStarted by Guest_k.kospit_* , 23 Feb 2022 |
