Teg Dehydration Unit Description
Posted 26 November 2012 - 11:23 PM
I need some explanation about the work pronciple of reflux coil condenser and Surge Tank in Dehydration Unit (DHU).
First of All My DHU has 60.25 MMSCFD (wet Gas).
I still confuse about the coil condenser?
GLycol reflux condenser (Coil) operating condition :
OP. Temp (Shell/Coil) : 212 F/112 F
OP. Press 9Shell/Coil) : 2.7 PSIG/75 PSIG
Still Colomn operating condition :
OP. Temp : 400 F
OP. Press : 3.0 PSIG
Reboiler operating condition :
OP. Temp : 400 F
Flash Tank operating condition :
OP. Temp : 112 F
OP. Press : 70 PSIG
Why do we need to install condenser unit since we know that TEG is still in liquid phase ?
I have read some articles about glycol reflux condenser. It said that the function of glycol reflux condenser to heat the glycol temperature. So I assume the condensation occurs in the shell side, that the small amount of TEG entrain with water vapour will condense and go back to reboiler. Am I Right ????
I also confuse in Surge Tank Unit. I have small amount of dry gas to be sent to heating coil in surge tank. That the dry gas will be the heating media in the surge tank. It flows inside the coil
The temperature of dry gas that leaves contactor is around 108 F. But surge tank uperating temperature is 384 Fahrenheit. How do i achieve that temperature since there is no burner system in surge tank.
Please Guys I nedd some explanation and enlightment.
Thank You Very Much For Your Help
Best Regard
Dandy Komboris
Posted 27 November 2012 - 01:11 AM
I think you didn't understand the process properly
Lean Glycol will be routed to surge drum with temperature as you said 384 F
Lean Glycol should be cooled before entering the dehydration contactor; you are probably using the dry gas for cooling the lean glycol.
Posted 27 November 2012 - 07:28 AM
Dandy:
Now I am confused. Where do you obtain the temperatures and pressures you cite? Some of these values are not normal or usual. Who designed and built your TEG dehydrating unit? I also do not agree with your process description. It would be much better if you submit a P&ID (or even a PFD) of your TEG unit.
I (nor anyone else, for that matter of fact) cannot furnish any explanations or “enlightenment” if we have no engineering description of your TEG unit – such as a detailed P&ID.
Based on some of the temperatures and pressures you cite, you seem to have a non-conventional version of what I would consider as a normal TEG Unit. I can furnish you a detailed PFD of a typical unit – complete with a detailed heat and mass balance. But you should furnish yours first since you are the one asking the questions. I have complete and detailed responses to each of your questions – but before addressing each one, I need a basis. And that basis is a P&ID or a detailed PFD with heat and mass balance.
I await your reply.
Posted 27 November 2012 - 10:54 PM
Thank you very much.
I though the surge tank heats the incoming TEG that come from the reboiler.
Posted 27 November 2012 - 11:13 PM
Here I attach some P&ID. But this P&ID lack of Heat & Mass Balance.
I also need some explanation about The Process that occurs in Glycol Reflux Condenser. Since the TEG boiling point above 500 F I assume that the TEG play the role as cooling media in the Glycol reflux condenser beacuse It's still in liquid phase . Am I Right ? So the Reflux condenser will condense small amount of TEG which is entrained by the hydrocarbon gas. Is That Correct Art ??
This DHP is designed by Cameron Japan Ltd.
Since you are the expert in this field perhaps you know which process that employ in this DHP ?is it Drizzo or Coldfinger.
This DHP Unit is buld in Cilamaya. Indonesia. Now the
Please Enlight Me..
This the inlet gas composition :
C1 = 98.56%
N2 = 0,0085
C2 = 0.0044
CO2 = 0.0015
Dew point = - 11 Celcius
H2O Content = 115 lb/MMSCF
Thank you very much For Your Help.
Best Regard
Dandy Komboris
Posted 28 November 2012 - 05:59 AM
I think it's better for you to study GPSA standard-dehydration part or other references like Kohl's gas purification book.
It will help you understand different type of dehydration processes and also your process.
Posted 28 November 2012 - 05:34 PM
Please refer to the attached Excel Workbook for my responses.
Thank you for your submittal of the P&IDs. My personal opinion of your process is that it is a cheap way to put together a TEG unit. I would not accept nor specify such a process. Just about every TEG unit presently operating in the Gulf of Mexico on offshore platforms is very similar to the process I have depicted in my workbook. And there is a sound and good reason for that.
Posted 28 November 2012 - 08:51 PM
Cheers,
Colin
Posted 29 November 2012 - 08:58 PM
I've seen your DHP P&ID. I am interesting about the TEG flow come out of Flash drum. In My DHP we send the TEG to Sock filter firtst and then send it to Charcoal filter. Is there any different result for this situation ?
Another difference is that In my DHP we use Hot,Lean TEG inside Surge Tank but in your desigh you use Cool,Lean TEG. You said that you wouldn't design TEG unit that way. Do you think there will be much TEG losses in my Surge Tank compare to your design ?
After All..
I would want to say Thank You very much for your cooperation and you've given me such enlightment about DHP.
I am very gratefull for that.
Best Regard
Dandy Komboris
#10
Posted 29 November 2012 - 09:06 PM
Thanks for the addtitional Information from you.
Yes we inject stripped gas from the second stripping column into the base of reboiler. We do it in order to lower dew point of treated gas.
Do u have any comment or suggestion for that ?
I would be thankfull for all your help
Best Regard
Dandy Komboris
#11
Posted 29 November 2012 - 11:45 PM
Regarding the filtration order, I prefer to have the particulate filter first so the carbon filter does not get plugged off by particulates. Depending on the type of carbon filter, installing the particulate filter downstream may make more sense. If bulk carbon is used in a vessel you definitely want a filter downstream to catch any carbon fines. I would still put one upstream as well. If a carbon canister/cartridge is used, put the particulate filter upstream to protect it from getting plugged off. Bulk media carbon offers the best performance, but results in a much larger, more expensive vessel due to the residence time required to work properly. Most on-shore (and many offshore) installations (that I have seen/designed/installed anyway) use the carbon canister/cartridge because of this. If money is not a concern, bulk media is the way to go.
As for the hot vs cool TEG in the surge drum, it is better to have the lean side of the L/R exchanger between the reboiler and the surge drum. Smaller units just use coils inside the surge drum to cool the lean TEG and preheat the rich TEG. The unit you have is an "unusual" design, first time I have seen TEG booster pumps as well.
Cheers,
Colin
#12
Posted 30 November 2012 - 02:46 AM
The reason why there are two booster pumps because we use it for loading TEG into the system. We do not have storage tank for TEG instead of that TEG is stored in plenty of drums in our Gas Station.
About "hot vs cool TEG in the surge drum", are you saying that it's better to have cooler TEG in the Surge drum ? So that you suggest I put Heat exchanger before the surge drum?
For additional info, This DHP is located near to Gas Station. We have 6 compressores ( 3 units of 1st stage compressor & 3 units of 2nd stage compressor)
Best Regards
Dandy Komboris
#13
Posted 30 November 2012 - 09:40 AM
Cheers,
Colin
#14
Posted 03 December 2012 - 03:34 AM
L/R exchanger ..
Can u tell me what is it?
Whats does The "L" and "R" stand for?
I never heard about it.
Forgive me
Best Regards
Dandy
#15
Posted 03 December 2012 - 07:18 AM
L/R = Lean TEG-to-Rich TEG heat exchanger.
#16
Posted 14 January 2013 - 12:45 AM
I have a question about Water Dew Point in Natural gAs.
Our Natural Gas has 98% Methane.
my operator has checked the water dew point temperature in 2 spot (Inlet Glycol contactor and outlet Glycol Contactor) but the result is the different compare to the Water Content of Hydrocarbon From GPSA Engineering Data Book 12th Edition.
Inlet Glycol Contactor
Pressure = 100.4 Psig
Temp = 78.3 F
Flow = 62.652 MMSCFD
Water Content = 79 Lb/MMSCF
Outlet Glycol COntactor
Pressure = 96.1 Psig
Temp = 76.3 F
Water COntent = 59 Lb/MMSCF
We use SHAW MOISTURE METER to measure water dew point.
When I use the Chart from GPSA Engineering Data Book for Water COntent of Hydrocarbon Gas Fig 20.4
I have different result.
If I use data from the Oulet Glycol COntactor
Temp = 76.3 F
I plotted the data then i have 240 Lb/MMSCF for the water content..
Should I calibrate my Meter Device or I was wrong for reading the chart ??
Pleae Help Me
#17
Posted 14 January 2013 - 10:29 AM
The whole point of the Dehydration unit is to remove the water. If you have 240 lb/MMSCF of water, you must have some serious hydrate issues downstream. What unit do you have downstream? Compression?
I suspect the graph you are looking at shows you the saturated water content, not the dehydrated water content. You won't have a simple graph to tell you this. The best thing to do is get lab results to substantiate your meter. Or even easier, look at your ProMax model's prediction of water content. See if that agrees with your meter.
#18
Posted 14 January 2013 - 11:01 AM
Here is a .pdf of the model.
Posted 16 January 2013 - 01:59 AM
Is That Hysys simulation ???
#20
Posted 16 January 2013 - 02:04 AM
Thanks for your input..
Is it possible If I want to recycle TEG in water vapour ???
From design Basis Our Glycol Losses is 20 Litre/Day.
So I Assume that we can get 500-550 litre/ month.
But I still don't know what would be the method to get The Glycol.
Reboiler Pressure is around 3 psi.
I Have two vessels in my plant.
Can I Use Vacuum system in the vessel to lower vapour pressure so that I can separate smaal amount of TEG in water Vapour ??
Best Regards
Dandy Komboris
#21
Posted 28 May 2013 - 10:57 AM
Dandy,
Sorry for the delay. I've been traveling a good deal.
To answer your question, that was a ProMax model. I never use Hysys for TEG units anymore.
That is a lot of TEG loss. Here are some ways to reduce the TEG in the Water Vapor:
Reduce the regeneration pressure
inject stripping gas into the reboiler
reduce the reboiler T
#22
Posted 10 September 2013 - 09:34 PM
Dear All
Can Two Phase Separator reduce water dew point in Natural Gas Stream ??
in the inlet stream i have nat. gas stream (136.5 Psig, 95.04 Fahrenheit, and water content is 138 lbs/MMSCF)
After the shore separator (2 phase separator) the outlet stream (132.20 PSIG, 83,84 Fahrenheit and water content is 87 Lbs/MMSCF)
Is this because there is a temperature decline so that the water content is reduced ??
Please help me.
#23
Posted 10 September 2013 - 11:35 PM
Dandy:
You need to learn phase equilibria and the saturated state of vapors and gases. A separator - no matter how efficient - is not capable of reducing the amount of water vapor contained in a volume of water-saturated gas. All a separator does is separate out the liquid particles entrained in the water-saturated gas stream. Lowering the gas stream temperature will reduce the amount of water vapor that can saturate the same stream. This is in accordance with Dalton's Law of partial pressures and should be something you already know and understand before you start using a simulation program.
The water content in a gas stream within a pipeline can be in two phases: a liquid phase entrained with the gas and a vapor phase that is the amount of water saturating the gas phase at the temperature and pressure of the flowing stream. When you say "water content" I am assuming you mean the amount of water vapor saturating the gas.
#24
Posted 14 September 2013 - 03:01 AM
Dear Art
You are correct Art.
When I Said "Water Content", meaning amount of water vapour saturating the gas.
In My DHU we have a big loss of glycoll.
Have You Ever found glycol losse in Reboiler Section ??
I mean there is a color change in my DHU because of glycol.
It can be seen now that many equipments in my DHU has "Yellowish Color".
The color is exactly same like Glycol spill in my DHU.
The reboiler operating Temp is 370 F.
Is there any chance that Stripping gas could carry some of the glycol or there is a leakage in my Coil Condenser 9Located in Top of my Still Column) ?
Thank You For Your Kindness Art.
#25
Posted 15 September 2013 - 09:35 PM
1) How much stripping gas are you injecting (scf/gal TEG)?
2) What lean TEG concentration are you trying to achieve?
3) What is your still column diameter and what type of packing?
4) What is the temperature of the vapour leaving the top of the still column?
5) What is the pressure of the regenerator?
Cheers,
![]() Fixed Bed Absorber Tsa UnitStarted by Guest_Sufy_* , 13 Mar 2025 |
![]() ![]() Molecular Sieve UnitStarted by Guest_Sufy_* , 26 Feb 2025 |
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
![]() Vacuum Getting Disturbed Periodically In Vacuum UnitStarted by Guest_aka28_* , 08 Oct 2024 |
![]() Teg DehydrationStarted by Guest_Root_* , 22 Aug 2022 |
